Page 3 of 14 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #21
    Philly
    Hey all, I'm having an issue that the remote Jumper (JU6) not turning my amps on...
  2. #22
    Apr 2008
    where do you connect the ignition cable? (the white one) for the m2-atx-hv
  3. #23
    Philly
    To the ACC from the Key Ignition.
  4. #24
    Apr 2008
    ok that answers my frist question, heres my new second one. when i turn on my car, the hdd starts the spin up, fans turn on, but it only gets half way through the post and stops, but when i hit the reset, it boots perfect.
    any suggestions?
  5. #25
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by mrroboto560 View Post
    any suggestions?
    Corrupt hibernation files?
    Are you sure your not using 'sleep' instead of hibernation?
    XP is notoriously bad with hibernation...
    Vista hibernation (when activated) works flawlessly on my rig....
  6. #26
    Apr 2008
    Quote Originally Posted by dasaint80 View Post
    i am actually having this problem too.
    Quote Originally Posted by WuNgUn View Post
    how can i fix the files
    yes hibernation, unless the GUI is lying to me... :-P
    which version of XP would be good with hibernation? i have XP home on my laptop and it works great.
    baa vista....
  7. #27
    Low Bitrate Ricksastar's Avatar
    Dec 2007
    CT
    whats the difference between the -hv and the other?
  8. #28
    _
    Mar 2004
    Little Elm, Texas
    high voltage input enabled.
    Jan Bennett
  9. #29
    Dec 2007
    CT
    so is that a better thing to have or does it not matter?
  10. #30
    May 2008
    what are all the wires for on the harness??
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 12:04 PM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 07:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
