Page 6 of 14 FirstFirst 1234567891011121314 LastLast
Results 51 to 60 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #51
    Aug 2008
    For the life of me I cannot find any instructions to connect the lilliput to draw power from the M2.
    Can someone point me in the right direction please.
  2. #52
    Mar 2006
    Colorado, but Canadian!
    yellow = +12v
    black = ground
    1.9in x 2.9in -- 47mm x 73mm
  3. #53
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    grab the car adapter, the center pin is the 12+(yellow) and the outside tabs are negative(black)
  4. #54
    Aug 2008
    merci beaucop
  5. #55
    Feb 2007
    Quote Originally Posted by cobase View Post
    I think we can include here that the J8 pins HAVE A POLARITY. Plugging the connector in backwards (50% chance!) can cause the M2-ATX to malfunction and be damaged! The board's manual says to check the polarity of the connections carefully, but many of us didn't think a simple switch had a polarity! (We're wrong because it's not a simple switch). Seems this has caused at least half a dozen board failures already, most recently summarized here:
    http://www.mp3car.com/vbulletin/powe...-problems.html
    Very disappointed because of this...
    Already bought (2) M2-ATX and apparently have damaged both of them due to this polarity issue on J9/J8 making that switch shorten and always powered. It's ridiculous since they don't properly mention this on the manual nor did they include +/- labels on the board, since when do you need to own a voltmeter to install a PSU???
    On the 1st PSU the damage is clearly seen, on the 2nd I'm guessing its less obvious... Who is the manufacturer? I think this deserves out-of-warranty RMA.
  6. #56
    Jan 2009
    Okay, i'm having a really hard time with the jumper settings. all the diagrams i see shows 4 rows a cross and 8 down but thats not what the board looks like. So can someone explain how to jump it so it is offdelay 5sec and hardoff 2 hours?
  7. #57
    Aug 2008
    Northern England
    Just bridge the pins labelled with the letter B with a jumper.
  8. #58
    Jan 2009
    damn i tried it and it wont shut down.
  9. #59
    Newbie Rescuer's Avatar
    Apr 2009
    Quote Originally Posted by aznd000d View Post
    Powering your LCD Monitor
    Quote Originally Posted by vladcarpc View Post
    Hi, here are some pics of how I did it.
    More screenshots in my Worklog.
  10. #60
    Jul 2007
    IL
    anyone have issues with this with RFI?
    Trying HD Radio and computer is causing a lot of RFI and destroys the FM signal. I'll be trying an AC PSU to see if there is a difference.
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 12:04 PM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 07:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
