Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 81 to 90 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #81
    Sep 2005
    Pomona, CA
    Quote Originally Posted by Sonicxtacy02 View Post
    just take the jumper off of the motherboard and short the pins together to see if the fans spin and it boots. That will tell you if its the jumper or something else.
    I tried taking the cable off the motherboard power switch pins and shorting them with a screwdriver and another piece of metal and nothing happened. I also have a molex > 4pin 12v connector going to the motherboard. I think I should get the 4pin > 4pin cable they have available at the store here and go directly from the PSU to the mobo, but I'm not sure if that's the problem. I just really think it's the M2 because if I turn it on it doesn't turn on my monitor, which is just spliced into a molex connector -and it worked previously that way.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  2. #82
    May 2009
    ^ the monitor won't turn on until the MB commands the PS to turn on the accessories...It does this by shorting the green wire to one of the grounds. Try that, it should turn on all the rails...
  3. #83
    Sep 2005
    Pomona, CA
    Do you mean the green wire in the ATX power connector harness? I don't think I want to cut that out and short it for this.
    Carputer Progress:
    Teardown PC [100%]
  4. #84
    May 2009
    Yes i mean that.
    You don't have to cut it out, just short it with an unfolded paperclip when it's unplugged from the computer!
  5. #85
    Sep 2005
    Pomona, CA
    Oh, so unplug it from from mobo and short it to one of the black wires?
    Carputer Progress:
    Teardown PC [100%]
  6. #86
    May 2009
    Yup! Can't hold me responsible for jumping the wrong ones though.
    Just google how to test a power supply to be absolutely sure. It's been a while but i'm almost positive it's the green one.
  7. #87
    Sep 2005
    Pomona, CA
    Ok, so it turns out it is not the power supply, must be the mobo or something on it...thanks joshuo!
    Carputer Progress:
    Teardown PC [100%]
  8. #88
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    well i hooked the ground up to the battery and it actually made it worse somehow. it HAS to be EMI... if i power down my computer and run the hdradio to my receiver its crystal clear even thought its using the same antenna
    Live mp3Car Facebook Chat
  9. #89
    May 2009
    Well the last thing i can think of is to move the radio further away from the computer...
  10. #90
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by joshuo View Post
    did that when i first got the radio.. its in the dash and my computers in the trunk. that DID improve the signal some. Perhaps its time for me to just drop dime and purchase another PSU to compare.
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 12:04 PM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 07:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
