Page 1 of 14 1234567891011 ... LastLast
Results 1 to 10 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
    _
    Mar 2004
    Little Elm, Texas
    This thread will serve to post all relative information for the M2-ATX 160 watt Intelligent DC-DC PSU or the M2-ATX-HV 160 watt Intelligent DC-DC PSU.
    This thread is not to be used for troubleshooting, but rather for FAQ type responses.
    Jan Bennett
    Dec 2006
    College Park MD USA
    I think we can include here that the J8 pins HAVE A POLARITY. Plugging the connector in backwards (50% chance!) can cause the M2-ATX to malfunction and be damaged! The board's manual says to check the polarity of the connections carefully, but many of us didn't think a simple switch had a polarity! (We're wrong because it's not a simple switch). Seems this has caused at least half a dozen board failures already, most recently summarized here:
    http://www.mp3car.com/vbulletin/powe...-problems.html
    Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Are you sure that is correct? It doesnt say anything in the manual that J8 has polarity.
    "The M2-ATX board has several wires that need to be installed in various places.
    When installing, always double check the polarity of your wires with a voltmeter."
    I always though that statement applied to things such as power or ignition wires. I blindly connected my power supply without regards to polarity and everything has been working for a few days. Which way is it +/- on the M2-ATX? On the EPIA M10000 mainboard, it actually gives the polarity of the power switch.
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Which pin is which on J8?
    Someone should link to that resistor swap that that guy did (can't find the thread right now)
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I just compared the specifications listed on the manuals for the M2-ATX and M1-ATX. Perhaps your theory on the polarization of J8 only applies to the M1-ATX? If you look on the specs table for the M1-ATX, the very last row says that J2, J4, J8, J6 are "Polarized Headers." However, on the specs table for the M2-ATX, this row has been removed. Maybe they redesigned the on/off header switch for the M2-ATX?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i dunno if this is true or not but it would completely explain why my last one died when connected correctly.
    and for my FAQ contribution here is the timing chart listing all available times (more than the listed times in the instructions)
    http://www.mp3car.com/vbulletin/atta...mperchart2.pdf
    Live mp3Car Facebook Chat
    FLAC WuNgUn's Avatar
    Sep 2007
    Why was I told (in another thread) that these power supplies came with the 4-pin, square mainboard aux. power plug? (See image)
    Product info says nothing of this....
    Can it be spliced in? Anyone know the pin-outs? Is there a female plug onboard that supports this plug layout?
    And what is the difference between the two M2's, the base and the HV model? Can't find any documentation on that either!
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Mine didnt come with the 4 pin plug..I think it is an addon that you buy separate. You can slice into it if you need +12 for some reason. Yellow is +12v, black is ground. You can just make the part yourself if you have the connector head.
    I dont know why the HV version is cheaper than the normal version. The only difference seems to be that the HV accepts up to 32v input, whereas the normal version accepts 24.
    Mar 2007
    Socal
    My M2-ATX does indeed have that 4pin P4 style connector in addition to the normal ATX 20pin.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Quote Originally Posted by cobase View Post
    Can someone confirm this?
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 12:04 PM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 07:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
