Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
Thread: M3-ATX 125 watt Smart Automotive Power Supply
  1. #21
    Mar 2006
    Colorado, but Canadian!
    The M3 fits the case vertically no problems.
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Newbie nemoid's Avatar
    Jan 2008
    914.ny
    awesome! thanks.
  3. #23
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    I have been using the M3 for almost 2 weeks now..works great..
    BUT the custom programming isnt the best.
    10 acura TL tech
    10 BMW S1000RR
  4. #24
    Dec 2007
    Sydney Australia
    Can you explain your post with some detail John.
    Is it hard to get the software to run or are the choices very limited ?
  5. #25
    May 2008
    Bend, OR
    Got one for my in progress car computer. Works nice, fits vertically in the voompc chasse.
    My only feature wish is that for a pair of pins to connect an override startup button if the ign is off, or override the shutdown sequence if pressed. This would allow the best of both worlds, leave the car and forget about it, but also turn it on w/o the car or sit in the car with the engine off.
  6. #26
    Oct 2006
    Florida
    Quote Originally Posted by RevheadKev View Post
    Sure what would you like to know?
    I bought the cable to set up the custom shutdown times but i havent tried it.
    ALso yes an extra pair of jumpers for a reset switch would be nice.
    I had to wire in series a toggle switch incase the PC locks up to reboot the power supply.
    10 acura TL tech
    10 BMW S1000RR
  7. #27
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Well Ive had an M3 for about four months now. The first one I received as part of the system had conventional sized jumpers installed by mistake (so it was getting intermittent set up information as the too large jumpers were not reliably setting it to power up in the configuration the jumpers were physicaly set). This combined with a motherboard problem led to having the MB and PSU RMA'ed.
    The new (same model) MB and PSU started up and ran fairly reliably (as far as the PSU was concerned) for a while. Little by little (about every ten start-ups at first) the PSU failed to start the PC when the vehicle started. This problem has grown worse over time to the point now that more often than not the pc does not start when I start the car (it starts the PC about two in ten times I start the car).
    I also notice that its not shutting the PC down properly (about three times in ten). Normaly it goes to "preparing to hibernate", when bar fills up, PC shuts down. About three times out of ten now it goes "preparing to hibernate", bar starts to fill up, screen goes black (PC fan still running), then screen comes back and says "preparing to stand by", bar starts to fill up but before bar fills up PC shuts down.
    Battery is fine, alternator is fine, ground should be good (same oem ground point as other processors in car and no errors in OBD, and this car had nine oem computers in it before I added the car pc, if there were ground or power issues, I would get codes).
    Im still using what we consider to be a problematic MB (waiting on a replacement, different MB) but aside from that, I cant see what Im experienceing with the start or / shut down as being anything other than PSU related.
    The red lead going to the PSU is off of a 20a fuse with a fuse tap (nothing else on that circut) via 16 ga copper (same guage as used from the molex to the PSU inside the system case). The only thing (other than the MB) that the PSU is feeding is the monitor (a Xenarc 700 IDT) via a power connector off the PSU.
    Anyone having problems with longevity (are they lasting under use) with the M3?
    Just an update : I guess the last time I pulled into the garage I was foolish enough to not watch the display like a hawk, because it must have put the machine into standby instead of hibernation . . .so . . .today when I went down to the car it was dead as a doornail. Gotta love my "intelligent" (but suffering from Altzhiemers) power supply.
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  8. #28
    Oct 2006
    Florida
    Ive been using mine daily for 6 months..been perfect so far.
    10 acura TL tech
    10 BMW S1000RR
  9. #29
    Mar 2008
    Melbourne, Australia
    hmm, there are some mixed opinions on here. I am planning on getting this for my current setup. anyone else have any input?
  10. #30
    Oct 2006
    Florida
    Well i am building another carPC for my new tahoe and im gonna use this again for sure..
    10 acura TL tech
    10 BMW S1000RR
  1. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  2. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Very Small/Mini Power ATX Power Supply?
    By xBrady in forum Power Supplies
    Last Post: 06-20-2004, 07:22 PM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
