Page 1 of 6 123456 LastLast
Results 1 to 10 of 59
Thread: M3-ATX 125 watt Smart Automotive Power Supply
    _
    Mar 2004
    Little Elm, Texas
    This thread will serve to post all relative information for the M3-ATX 125 watt Smart Automotive Power Supply.
    This thread is not to be used for troubleshooting, but rather for FAQ type responses.
    Jan Bennett
    Jan 2008
    I was thinking of trying one of these for a new build because of the size. If I needed more power later on for upgrading could 2 of these be run in parallel without problems??
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Subscribed. I've been looking at thees pico supplies to save on space, this one is the highest wattage available. I'm a owner of (2) m2-atx power supplies that still run to this day (2 years later) so I was instantly intrigued when i noticed a m3 was available!
    Couple Q's
    Does the entire PSU plug right into the ATX socket?
    How many Molex connectors does it have?
    What is the wattage available on the 12v rail?
    Constant Bitrate djchicago's Avatar
    Chicago Ill
    OK so I have one, I know how to plug it into the board but what is next? there are three wires RED<BLACK<WHITE, please explain the hock up. Also there is a small black connector with three wires on it as well, can someone explain how this connects to the PSU and the motherboard Thanks
    Aug 2006
    The instructions should be in the package, no?
    From what I know from M2, it's 1 for power, 1 for swich and 1 for ground.
    Variable Bitrate redls1bird's Avatar
    Feb 2006
    Car Pc progress meter:
    [-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Chicago Ill
    Great I got the instructions, there was nothing in the box but the PSU, are there jumper needed if so I will have to find some
    Feb 2006
    Ive ordered one of these, and will post a writeup with some basic information here and in the reviews section once its set up.
    My worklog
    _
    Mar 2004
    Little Elm, Texas
    so I realized that the owners manual for the M3 was not provided on the product page on our store. I have now uploaded it.
    It should answer all of your questions: http://store.mp3car.com/M3_ATX_125_W..._p/pwr-029.htm
    Jan Bennett
    Chicago Ill
    ok so maybe is not a problem but I tried the "Thump" connection (grey wire) and it will not cut on my amps. I even tried to connect a 30amp sp relay but no go (no enough power to activate the relay). Thats a bummer.
  1. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  2. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Very Small/Mini Power ATX Power Supply?
    By xBrady in forum Power Supplies
    Last Post: 06-20-2004, 07:22 PM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
