I want one of these! any help please?
This thread will serve to post all relative information for the Carnetix CNX-P1290 Dual Output 90 watt Regulator.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Jan Bennett
Unless you can find one used, you won't be able to get one.
They are no longer being made.
Jan Bennett
Am I just going to have to break down and buy the p2140? i dont need usb monitor or n e thing. and it would be nice to save the $35
Well, if it's not being made any more...![]()
Jan Bennett
I got this, and it's been great!
Got one problem though... When I turn the key, I hear the "beep" from the pc booting, and the it dies... I had to take the cable out, and manually get into the boot of my car to push "Power" on the pc...
Anyone knows what could be wrong?
If you can't drive a stick... You can't drive!
My P1290 is going into forced shutdown 60 sec after IGN is applied.
I removed it from the vehicle and am testing on a bench supply and getting the same problem with no load.
Battery/ alt voltage good - confirmmed with a bench supply
Same problem with no load connected
ANY IDEAS?
Firmware?
Internal short?
Details:
P1290 V1.0.0
Led Sequence:
-Power on firmware flashes ok -Firmware vers 2.3
-left led flashes a few times then solid
-right led solid
-both leds are solid for 60 sec
-left led 12 fast flashes then supply makes small chirp right led goes out ( output drops to 0v )
-left led flashes fast and right led slow
-left led flashes fast and right led solid
