Results 1 to 8 of 8
Thread: Stand By on DSATX
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    Stand By on DSATX
    Does the DSATX allow standy by (sleep) mode even if ACC goes low? I had the brainstem hooked up and it says sleep mode is enabled but as soon as ACC goes low it begins the countdown timer then after 90 seconds it does a hard shutdown. So I'm wondering if it even allows sleep even with ACC low? Thanks in advance!
    Elsewhere
    There's a parameter that needs to be set so it doesn't do a hard off.
    It's in the manual.
    How about the Wiki?
    Mar 2005
    FL
    Ok, I looked over all the parameters but I'm not really sure what I'm looking for. Are you talking about the ENABLESHUTDOWN parameter?
    Mar 2005
    FL
    Anything?
    Elsewhere
    Set ENABLE5VSBOFF to 0
    How about the Wiki?
    Mar 2005
    FL
    Ok, thanks! I'll try that and see how it goes. Thanks again!
    MarcelP's Avatar
    Nov 2007
    Germany
    and? does it go? I have the same problem.
    My Project: German/English
    Mar 2005
    FL
    Yup, this works.
  1. DSATX firmware bug?
    By zenfe in forum Power Supplies
    Last Post: 10-04-2008, 04:56 PM
  2. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  3. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  4. DSATX serial diagnostics spits out garbage
    Last Post: 11-14-2006, 03:21 PM
  5. dsatx issue
    By gameboy in forum Power Supplies
    Last Post: 02-25-2006, 05:12 PM
