Results 1 to 10 of 12
Thread: Laptop Power Supply Hums When Connected To Inverter
    Jan 2008
    Dartmouth, MA
    Today I was in a hurry and my laptop battery was dead so I plugged my laptop into my power inverter. When I plugged it in, the laptop's power supply made a constant humming noise. It doesn't do this when plugged into an AC outlet. What could be the cause of this?
    Thanks,
    Paul
    Mar 2006
    Colorado, but Canadian!
    Noisy inverter. This is why we regard inverters as a bad solution. The cheap ones are really really cheap! For that to not happen you need to use a true sine wave inverter which is really really expensive.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    Dartmouth, MA
    Would using a "cheap" inverter damage the equipment connected to it?
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    An inverter doesn't supply a true AC sine wave like the outlet in your house does, it supplies a modified or "stair step" sine wave. This can cause certain electronics to behave differently than they do in the house.
    Unless your power supply is running hot, smoking, or doing something else alarming, I wouldn't worry about it.
    Mar 2006
    Quote Originally Posted by PaulF View Post
    Quote Originally Posted by jontz View Post
    I doubt it will damage anything.
    But if you want to see some really funny stuff, take an old old alarm clock. They use the 60hz signal from the wall to time their clock pulses. So for isntance if you hooked it up in a 50hz environment it would be (50/60)% slower. Hook that up to a cheap inverter in your car, and all hell breaks loose! it will start to randomly fling time. Hours pass in no time.
    Dec 2007
    Quote Originally Posted by 2k1Toaster View Post
    AHHHH .... so thats what they do to cab meters on new years eve??? No wonder my cab fees were $200 for 6 miles
    Jan 2008
    Dartmouth, MA
    Alright, as long as I'm not doing damage, I'm happy. Just out of question though... if I were to hook up a computer UPS to the inverter, would it change the modified sine wave to a true sine wave?
    Dec 2007
    Osceola, IN
    Nope
    Jan 2008
    Dartmouth, MA
    See now I was planning on hooking up a home stereo self-powered sub woofer to this thing for a few months before I get my new system. I'm guessing that I'll get a nice little hum there too, correct?
    Dec 2007
    Osceola, IN
    It depends on the amplifier in the sub, but there is a good chance you will. The only way to know for sure is to try.
  1. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  2. Replies: 7
    Last Post: 02-08-2007, 04:39 PM
  3. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  4. Replies: 21
    Last Post: 04-05-2005, 10:54 AM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
