Results 1 to 5 of 5
Thread: smart shutdown with acer L100
    May 2005
    i have an acer L100 just put together with xp black amd am2 cpu 400gig sata drive , 2 gigs ram, blue tooth dongle , it has a laptop like power brick is there a way to have smart shutdown with this setup, with power brick and without
    dying to get this setup in my truck
    thanks guys
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    You could buy a regulated SDC ( shut down controller ) that puts out 12v and 5v.
    This is good if you plan on powering a touch screen and usb hub.
    Carnetix makes one that does this nicely.
    Or you could use some relays to control things, cheaper but if done right works as well.
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I'm using the Carnetix 2140 with my Acer Power 1000, which is an earlier version of the L100. Shutdown works well, but you need to be running the Psumoni application in the background, or foreground, or embedded, just needs to be running.
    I am having problems at startup when its very cold. I believe when the hard drive spins up its shutting down the 2140. I haven't spent much time to troubleshoot it tho.
    TruckPC - gutted, being used for test setup
    BoatPC - off season - Inelmac screen needs serviced again!
    BlazerPC - last vehicle PC I'll build
    Low Bitrate kirk78h's Avatar
    Apr 2007
    Bel Air, MD
    Quote Originally Posted by xmoDDer View Post
    thanks guys
    I've been thinking about reformating my drive and switching to XP Black. I'm mainly looking for improved boot times. XP, even with services stripped, etc. is slow to boot. What kind of performance are you seeing with it?
    May 2005
    xb black
    Quote Originally Posted by kirk78h View Post
    by saying xp i meant the black edition amd am2 cpu, not windows xp black that thing slows down big pcs much less a car pc, noob i am but that i wouldnt do
    any info or diagrams on the relay setup i have 17 years in caraudio so the relays shouldnt be a problem
    also what type of apps do i need to run in the back?
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
