Results 1 to 10 of 13
Thread: inverter making pc do werid stuff
    Feb 2000
    hoppers crossing, victoria, australia
    hiya all
    ive got myself a lil setup thqat i had installed a few weeks ago a 12" lcd and a p2 233 powered by a 300w inverter
    now running from house power everything is fine boots up works perfectly but when powered by the inverter every now and then it dosnt recognise the video card and i have to reboot it
    its damn annoying
    anyone got some ideas
    cheers
    pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Oct 2001
    Ontario, Canada
    how often does this happen?
    do you have access to a different video card that you can try?
    do you have access to a different inverter that you can try?
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Feb 2000
    prolly every 2-5 reboots (btw its actually shutdown properly)
    its a lcd controler card and its the only one i can use
    nope sorry no onther inverters
    another thing ive noticed is that when the inverter is on but the pc is off the psu(atx) makes a weird buzzing noise
    dunno if that has something to do with it
    cheers
    pcman
    Oct 2001
    Ontario, Canada
    There's a filter circuit that you might want to cut out of your PSU. do a search on here for it and see what you can come up with.
    BTW - does your signature need to be 16 lines long? It's just a bit of a pet peeve of mine and some other people, when you post a 2 line message and have 16 lines of signature. You could just put it all on a couple lines. Just a thought
    Jul 2002
    If you have a good quality inverter you shouldn't get any problems like that. Perhaps it outputs a square wave rather than a sine wave?
    Best regards,
    Matthew
    Feb 2000
    umm yeah filter bit ill do a search
    as for the sig yeah ill fix that
    arnt all ppl using square wave inverters as sine wave are $$$$$
    cheers
    pcman
    Apr 2001
    Here, There, Everywhere
    mr pcman,
    yeah the buzzing is due to the filter circuit on your ATX PSU having trouble with an inverter square wave output.... on my system the buzzing transfered into buzzing on the sound card output, in your case it might just be causing some video card trubbles?
    and yeah true sine wave inverters cost alot! but I have found all the square wave inverters I have used to be fine....
    Project - GAME OVER :(
    Feb 2000
    hacking time
    looks easy now that ive seen the piccies on ya website
    cheers
    pcman
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Also, are you sure its the inverter? Its certainly a probable culprit, but could the card be coming slightly loose from the vibrations of the vehicle?
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Feb 2000
    its not the card coming out cause the lcd still power up from it
    and also because sometimes a simple reboot and it detects the video card
    ive just ripped the top off my psu and its weird like a early atx and it has a seperate converter for the 3.3v weird stuff
    looking at it now theres a big white squar cap across the power input and a transformer/filter thing in thepower line
    gonna chop em out replacing the filter thing with wire links
    cheers
    pcman
