Results 1 to 6 of 6
Thread: Dell Optiplex GX150
    Dec 2007
    Dell Optiplex GX150
    Hy
    I have see on this forum that many of users use dell optiplex GX150(p3), for this reason i`ve decide to buy this pc.
    1000mhz Processor, 128Mbram(will change whit 512mb), onboard videocard,and soundcard(dont know if it change...the future will decide).
    My big problem is the supply.somebody have modify the original supply or make other(bild it and not buy it)
    I see some connection diagram and it dont have only 2voltage input(5v and 12v)!
    The 11pin(from connector) start the pc?no?but how?to the ground?(like a normal ATX supply)?
    can somebody give me more info from this board.
    thanx
    Dec 2007
    Supply
    My Dell optiplex GX150 pinout:
    One side:
    1. Orange
    2. Orange
    3. Black
    4. Red
    5. Black
    6. Red
    7. Black
    8. Gray
    9. Violet
    10. Yellow
    Another side:
    11. Orange/Brown(2 wire)
    12. Blue
    13. Black
    14. Green
    15. Black
    16. Black
    17. Black
    18. No cable
    19. Red
    20. Red
    The voltage on my PSU
    Red +5V
    Black - GND
    Orange +3.3V
    Yellow +12V
    Gray +5V
    Green +5V(stand by)
    Violet +5v(stand by)
    Witch is the POWER/ON?
    And witch is the GOODPOWER?
    Dont know why is voltage on 2 wire in stand by?the Gray and Blue wire for what represent?
    i`ve attach some picture about my plug and one whit dell supply but is not good for me
    please give me some detail from dell supply.
    Thankx
    Dec 2007
    Need power supply for the car
    All day have search for the pinout for my mobo and in final i find it
    To start PSU it need to conect 14(green) to the ground.
    At my psu the 18(white) is mising.
    11(orange/Brown) use to regulat the supply.
    Now it need to make one supply witch work on the car, or modifing this.
    can sombody help out.
    Under construct: Dell Optiplex GX 150
    Newbie g35mike's Avatar
    Nov 2007
    South Carolina
    I am using a m2-atx and this adapter in a gx 200. http://www.endpcnoise.com/cgi-bin/e/...=dellconverter
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The GX150 use standard ATX connector.
    Check this thread for the pin out for the HD, Power switch, ... Led and such I posted (if you don't have to panel board.)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2007
    @g35mike my psu have only 1 power plug(20pins) and it is diferent from that you post....it is no problem i can handle this....my problem is supply how to modify an existing220v supply to the car?!
    @MatrixPC
    It will be replace my P3 setup in the Supra. So it will be power by my custom built sproggy
    in finaly this supply have use?
    can post the schematic?
    My pc is complet nad i have the switch panel but dont know if will use it.
    ps. i buy the pc whit 128mb(pc 133) ram and i have 1pice 512mbram(pc 133) but whit this module dont start the pc!
    on this site http://support.dell.com/support/edoc...n/ug/specs.htm it support the 512mb!
    why cannot use it?the PC dont suport 512mb in single module?
    128mb is to little for my carpc.
  1. FS: Dell laptop power supplies
    By wrxmaster in forum Classified Archive
    Last Post: 08-10-2006, 09:41 PM
