Results 1 to 10 of 13
Thread: Can't decide on power source
    Oct 2005
    I have a Cobra 800 watt invertor and an AOpen case with a 160watt built in PSU that you would normally plug into the wall. Should I plug it into the invertor, or buy a dc-dc psu with a shut down controller? I want to run 5.1 sound through RF amps and MB Quart speakers. THanks
    Elsewhere
    A DC-DC PSU is always the preferred option.
    How about the Wiki?
    Feb 2007
    Kenora, ON, Canada
    DC-DC...more straightforward, less hassle with eliminating noise from the system. Especially if the inverter you have is not a true-sine wave inverter.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Lovin' my dsatx............
    Leonardo Da Vinci
    Newbie g35mike's Avatar
    Nov 2007
    South Carolina
    M2-ATX has worked 100% perfect
    Jan 2008
    M2 here also.
    Once you've had the "Carputer" experience, you will wonder how you ever lived without it...
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I ran an inverter just fine for over a year. Yes, they are electrically noisy, but your average ATX power supply should run just fine off an inverter. However, my screen always had this flicker when run from the inverter. I just made the switch to a M2-ATX, and it is great. Very efficient and clean power to the PC, no more flicker. Might as well go DC-DC and get it right the first time, because eventually you will probably want one.
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    I went with an M2-ATX as well...I am an efficiency freak, and DC-DC is definitely more efficient and less noisy.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    No argument on the lower noise produced by the DC-DC.
    But what do you think the efficiency difference is?
    ... enough to require a thicker wire?
    ... enough to effect fuel economy?
    Low Bitrate ZoLtRiX's Avatar
    Nov 2002
    Niagara Falls, Ontario
    Inverter
    I tried running a PW-200-M 200W DC-DC Mini ITX ATX 12V Power Supply PSU to run my full size mother board, it was either it would work or it wouldnt when trying to power up. when It would work, I would get flickers on my LCD. Was ****ing me off, Tried everything to get rid of the flickers, I coudlnt, I went back to the old power supply with inverter, I have no flickers at all, I think Im gonna stick to my 350 watt inverter and PSU.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. Update: 2-12-05.. Flash Support!...
    By guino in forum Road Runner
    Last Post: 02-13-2005, 01:21 PM
  3. Lilliput Power source needed
    By R3l0ad in forum LCD/Display
    Last Post: 01-10-2004, 10:28 AM
  4. Here's an alternative power source....
    By A Boy and his Miata in forum General Hardware Discussion
    Last Post: 11-21-2000, 12:44 PM
  5. About a power source
    By SuperAJ in forum General Hardware Discussion
    Last Post: 08-04-1999, 08:41 PM
