Results 1 to 10 of 10
Thread: Opus 320 - ATX, BTX, 24 pin, 20 pin... huh?
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    So I ordered a 320 watt PSU direct from Opus, and when you add it to your cart, it gives you the choice of "BTX - 24pin" or "ATX-20pin" (the mp3car store does not give any options?). I had ordered a microATX motherboard the same day, so I chose the "ATX" option since it seemed logical. So of course I get my motherboard today and it's 24 pin.
    I have not received the 320 yet, but I'm going to go ahead and assume that it's going to have 20 pins when it gets here. So why was the 24 pin option called "BTX?" I assume the 20 pin connection from the Opus will not run my motherboard? But why is there no option in the mp3car store?
    Confused.
    Jan 2007
    New Orleans, LA
    Just read the manual online and it only mentions including a 20-pin cable. I also quite often see pics of motherboards with a 24-pin socket with 4 of them covered up by a yellow sticker.
    I thought I was pretty well-versed here, but I'm apparently slightly confused. Perhaps my questions will be answered when I actually receive the PSU. Sounds like I might need to send it back and exchange it for "BTX" though.
    Elsewhere
    20 to 24-pin adapter.
    How about the Wiki?
    Jan 2007
    New Orleans, LA
    Thanks DP. Are you saying that's what I need, or are you saying that the Opus comes with this?
    Elsewhere
    That's what you need if your motherboard has a 24-pin ATX connector.
    How about the Wiki?
    Jan 2007
    New Orleans, LA
    Ok.
    Jan 2008
    Norton, MA
    The guys at OPUS seem to be pretty reasonable people. I would think you could give them a call or send them an email and see about getting a 24pin cable.
    I just ordered a 320 and saw the same thing, I knew I would need 24pin though as I think its the standard now. I also had no idea what BTX was thought. I got it a few days ago but sadly it was a 250w instead of a 320, however on the PSU board it has a 24pin and then on the mobo side it has a 20 pin with a 4 pin addon and then the second 4 pin piece. I am thinking now maybe yours will come the same way and you will be all set.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
    Jan 2007
    New Orleans, LA
    jdc, you are right. Mine came with that too, so I'm good to go.
    Jan 2008
    Norton, MA
    Great good to hear. I'm still anxiously awaiting my 320 to arrive so I can get my "case" all mocked up and ready to install into my truck.
    Enjoy your PSU.
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Jan 2007
    New Orleans, LA
    Just finished installing mine in my case. Still have to hook it all up now.
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 12-16-2006, 12:21 PM
  2. connecting a PSU to a board which doesn't a have 20 pin connector
    By al_kaholik in forum General Hardware Discussion
    Last Post: 12-02-2006, 03:21 PM
  3. M2-ATX Question - 24 Pin Motherboard w/ 4 PIN CPU
    By tbird2340 in forum Power Supplies
    Last Post: 02-15-2006, 02:57 PM
  4. WTB: 20 pin ATX Power Cable for Opus 120
    By Shelbrain in forum Classified Archive
    Last Post: 02-04-2006, 02:23 PM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
