Results 1 to 3 of 3
Thread: Which wire first?
    Mar 2007
    Which wire first?
    Before I hook up my M3-ATX, I remember someone on this forum saying something about hooking up a certain wire first or you could fry it. I should assume ground. Which order should I go? I've got 12V from the battery, a ground and a fake "ignition" wire which is just basically another 12V battery source with a switch in line. All this with a 20Amp fuse.
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    You should wire up your positive wire first. That way, if you make a mistake and touch something that you shouldnt, you wont have a ground to fry anything. When your attaching the ground wire afterwards, if you make a mistake and touch something you shouldnt, you wont hurt anything because the ground wire carries very little current. Also, you should connect these things with the ground cable on your battery disconnected just to be on the safe side.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by redls1bird View Post
    ...the ground wire carries very little current.
    The ground wire carries the same current as the positive wire.
    Personally I'd hook the wires up in the order : ground, positive, ignition.
  1. Replies: 13
    Last Post: 04-08-2010, 03:38 PM
  2. Question for Zootjeff, What's the DSATX white wire for?
    By greatwhite in forum Power Supplies
    Last Post: 10-21-2007, 12:18 PM
  3. Question about wire to connect to battery
    By thanassius in forum Power Supplies
    Last Post: 08-07-2006, 10:35 AM
  4. Totally dissapointed with my carputer!
    By Maheriano in forum General MP3Car Discussion
    Last Post: 07-16-2006, 08:26 PM
  5. Pseudo-FAQ: What Do I Need For A Carputer?
    Last Post: 07-03-2006, 02:04 PM
