What are the power jumpers set to on the M2?
Aron
Right, i started getting my build fully in place about 3 days ago, I put all the wires in, ran the switch from my headunit to the PSU, and it was a no go, I tried it on my amp - no go, apparently 0.1v isn't enough.
I decided i'd just run a 12v line that was switched, works perfect on my 2 amplifiers, but the m2 just turns the pc on, when the 12v is off, it stays on.
what am I doing wrong?
i made sure to go through windows settings and make sure that the 'what do I do when the power button is pressed' was set to turn off the pc.
what other things may cause this issue?
Aron
Absolutely 100% stock
I think it's set at 30 minutes when new. So...the PC won't turn off for 30 minutes. Read the papers that came with it and set the jumpers to whatever timing that you want.
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
