You can change the pulse width from the brain stem. It should be in the manual for the DSATX. Just search for the word Pulse Width.
Bought a DSATX and Brainstem to replace the M2ATX been running but suspected needed a little more power.... replaced and tried starting but cpu fan spun for a few seconds and then shut off, DSATX was running - led's on ps and brainstem were both on solid.
Little research and found that the motherboard(ECS AMD690GM-M2) requires a 50ms turn on pulse and factory settings for DSATX are 10ms.... so how can I get this changed since I cannot get the computer to boot or how can I get the computer to boot in this situation so I can change it???
TIA
Rick
Yep, I know - but need to get the computer up before I can change it.....
Think I found it - just need to jump the motherboard ps pins for a bit
Now if it will just warm up here I can get out there..............
