Results 1 to 6 of 6
Thread: 19.5v from p2140 set to 20v?
    Jan 2008
    anyone running it, or otherwise sure it will work?
    will power: Dell Inspiron 9100 (19.5v/150w)
    Xenarc 700TSV
    USB devices with 5v add-on.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    You could put a honking diode in series to drop it half a volt.
    Otherwise the regulators in the pc will have to work a little hotter.
    Jul 2006
    Quote Originally Posted by jb33 View Post
    Xenarc 700TSV
    youlll be fine
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Anyone know which PSUmoni version to use on a just purchased 2140 power supply? There's like 3 different versions of it and I don't know which one to install?
    Jul 2006
    dont install 1.83 or whatever it is if you need the option to leave your secondary outputs on while the thing is in standby.
    Jan 2008
    Covina, CA
    Which firmware version do the 2140 come with. Just got mine from mp3car today. What version you suggest running?
  1. P2140 mini install questions.
    By hondamac in forum General Hardware Discussion
    Last Post: 08-22-2007, 11:23 PM
  2. Set up stage in need of help desperatly.
    By TimStark in forum Newbie
    Last Post: 11-16-2004, 11:56 PM
  3. Dual monitor set up and function?
    By dogger in forum Newbie
    Last Post: 10-09-2004, 07:58 PM
  4. Replies: 1
    Last Post: 06-18-2004, 05:49 AM
  5. need help with my set
    By CorollaVerso'04 in forum Newbie
    Last Post: 04-18-2004, 03:32 PM
