Results 1 to 3 of 3
Thread: Powering on M3-ATX for testing
    Jul 2006
    I was wondering if I can hook up a regular power button switch to the motherboard and connect the (+) + (IGN) to the battery, (-) to ground and use the power button to turn on the PC? I want to make sure everything else is working before I pull apart the console to get to the (ACC) connection.
    Kevin
    Epia Nano ITX N10000E, Morex 1677 Case, 1024MB RAM, TSST Slim DVD/CD-RW, 60GB Fujitsu Notebook HDD, Win XP Home/Mandriva 2008 Dual Boot
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    If you mean connect the ign wire to the same constant power source as the power wire, then use the normal momentary switch to start up then, most likely, yes. Its how mine is hooked up right now, but for me, its because my motherboard doesnt respond to startup and shutdown commands through the atx connector. If your motherboard does respond to those commands, it may cause problems with shutdown or start up. I cant really say.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Just put the switch in between say a cig lighter connection.
    So yes i think that should work fine. Its just a 12v signal to power on the M3.
    10 acura TL tech
    10 BMW S1000RR
  1. Powering M1-ATX with CPU ATX power supply ???
    By jwh02017 in forum Power Supplies
    Last Post: 10-18-2006, 09:42 PM
  2. Powering a Standard ATX board
    By simbot41 in forum Power Supplies
    Last Post: 12-16-2005, 12:38 AM
  3. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  4. powering a VIA MII w/ a ATX powersupply
    By boostedGT-S in forum Power Supplies
    Last Post: 01-20-2005, 01:57 PM
  5. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 04:19 AM
