Results 1 to 3 of 3
Thread: additional power supply for clearwire modem?
    May 2007
    Bothell, WA
    im thinking about getting clearwire for my car so that i am able to have wireless highspeed anywhere i go in my car. i right now, i am running an aopen minipc with a lilliput touch screen. i have two usb hubs, one just for occasional uses in the center console for ipods, thumbdrives, etc. then one main usb hub which has the gps receiver, usb touch screen, usb radio, bluetooth, wifi, and wireless keyboard/mouse.
    for my psu, i have the carnetix p1900, soon to install the p2140 with the additional 5v regulator for the main usb hub. so basically my psu is powering the usb hub, screen, and pc. the clearwire modem is a 12v system, and i was wondering, would i need an additional psu just to power that? or is there any way i can have it so that its also powered by my current psu? what would you suggest for my plan? can i run two 12v systems off the one 12v outlet? or would that be not enough power then to run my screen and modem? thanks for any help in advance!
    Elsewhere
    AS long as it doesnt overlod the PSU that you're using now, you could tap it for 12v for the clearwire unit.
    Use yellow & black from a HDD power connector.
    How about the Wiki?
    May 2007
    Bothell, WA
    how would i know whether it overloads the psu or not?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  3. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  4. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
