Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: AC - 12v DC Converter For Testing
    Feb 2006
    Question AC - 12v DC Converter For Testing
    Hi all--
    Not completely sure how to categorize this inquiry, but I'm interested in an AC - 12v DC converter that will allow me to safely power all of my car components in the house using mains AC as the ultimate source. The interest here is in testing ALL components to make sure my setup works under simulated 12v battery connection before installing it in the car.
    Here is what I wish to power under simulated car battery condition, in the house:
    1. P1900 (to which is to be connected an Intel Mac Mini and VGA-RGBS scan converter. The Mac will have connected to it a USB hub, USB screen coordinate converter board, USB wireless keyboard dongle, and USB audio adapter)
    2. Factory NAV system, which includes RGBS monitor and 6-disc CD changer
    3. Three 12VDC relays
    My interest is in finding an AC-DC converter that delivers safe, sufficient power to the above setup, in the correct voltage-- That which basically acts like the entire system is connected to my car's battery. I cannot stress enough that this needs to be a safe power supply, as the components to be powered are far too expensive and valuable to risk blowing.
    Thanks for your thoughts on the matter, everyone.
    Banned
    Jan 2008
    Just use a regular power supply inside the house for testing purposes.
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Yeah u simply need a power supply of maybe minimum 3-5 Amps. I have this one here that I had for years.
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Sep 2007
    West Springfield, MA
    What if you were to buy two lantern batteries from the local sporting goods store. Wire them up in series so that you have 12 volts? They may not last long, which would be the only problem. You might be better off trying to find a 12v battery from a "Power Wheels" vehicle. They'd be cheaper than the $100 supply the above link is suggesting, and I'm sure they'd power a computer for hours.
    Feb 2006
    Thumbs up Thanks Very Kindly!
    Thanks very much for your help in this matter, all-- I hope not to be too much of a noob in this regard-- I'm just really concerned about protecting the components I need to work with. They constitute considerable $$ !
    I'll likely go the route of PC power supply. I have one on hand already, and with some minor modification it appears such a thing will suit this need perfectly (and inexpensively, to boot-- A great thing if you haven't ample financial reserve, such as I! ).
    Tallyho!
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    just use the a computer's PSU
    or buy a cheap 300W computer PSU and if you jumper the right pins on the ATX plug you can use it as a 12 and 5v power supply. just tap into one of the plugs for the hard drives and take the 12V side of that. as shown in the link above
    Jan 2008
    Santa Clara, CA
    Here is what I have been using... works perfectly!
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=012
    I'm not sure if it's still available though...
    Oct 2007
    Auckland
    my only concern with that would be power draw on it, as its only 4amps (about 50W) you may depending on your loading not have enough grunt to power your whole rig
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Hack an ATX power supply to get only the 12v outputs. 250w PSU usually have ~10 amps on the 12v rail (120 watts) and are dirt cheap.
  1. DC Input AC output using MPI-400
    By sathish17110 in forum Power Supplies
    Last Post: 12-27-2007, 11:43 AM
  2. dc - ac power inverter
    By dasaint80 in forum Power Supplies
    Last Post: 12-10-2005, 04:16 PM
  3. new 200 watt PW200M DC DC converter?
    By Xtreme2k2 in forum Power Supplies
    Last Post: 06-06-2004, 05:04 PM
  4. Replies: 5
    Last Post: 08-20-2002, 09:29 PM
  5. why not to use zener to make 12V DC??
    By embedded in forum Power Supplies
    Last Post: 04-26-2001, 09:54 PM
