Results 1 to 5 of 5
Thread: DSATX w/brainstem Problem
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Question DSATX w/brainstem Problem
    I have recently purchased the dsatx and brainstem.
    I am bench testing everything right now, so here is my setup for the dsatx:
    - Similating atx power by jumping pins 13/14 on atx power supply.
    - Attached a switch from acc on dsatx to 12v on molex
    - ground from a molex
    - running vin to 12v molex
    When i power up the dsatx it seems i never hit post. I get it to boot up probably once every 10 times. Everytime i boot from the dsatx a solid red lite is on and then i get no vga signal on my monitor.
    I tried it on another computer and boots up fine with vga everytime. So, looks to be a problem with compatibility with my motherboard and the dsatx or something. I am using a MSI motherboard running an amd xp processor.
    Also, with the brainstem hooked in i get a solid led, but when i give it power the dsatx doesn't get power it seems, no blinks nothing. When i disconnect the brainstem the dsatx boots up fine.
    I know i have it in the right way, bucasue if i put it in the otherway the led flickers and doesn't get reconize on startup, but am able to boot.
    Maybe i hot plugged the brainstem and need to reset it, which i havent' done yet, but wondering if i'm doing something or maybe its my motherboard. Even if i did hot plug the brainstem, shouldn't it still boot and just act weird?
    Just wondering if anyone has experienced this with either situations above?
    Also, i have tried 3 atx power supplied to similate power, but i could only get one of the atx psu to works. With the other 2 the dsatx doesn't get power which is weird. I used a volt meter to test the volts on the psu that worked, so will test the other 2. Thought that was weird..
    blair.
    Zerach's Avatar
    Jul 2005
    Quote Originally Posted by TeamRSX View Post
    blair.
    You also need to short\jump pins 8/9 on the ATX PSU.
    Zerach
    CentraSkin Developer
    Try out the new version of CentraSkin V.52
    Click here to get CentraSkin V.52
    MarcelP's Avatar
    Nov 2007
    Germany
    I have a problem with the Brainstem adapter. If I it to the DSATX do not attach start my PC any longer correctly. It starts, goes out however equivalent again. And the LED of the DSATX flashes 4 or 5 times. What does that lie?? If I the Brainstem do not attach function everything normally. A RESET I made, it help also not.
    My Project: German/English
    Feb 2007
    netherlands
    i had the brainstem on com 3 and it worked reasably wel. Because of a new position of the mobo, now i use com 2 and when i switch to the gps program, al power goes.
    I use a m2 to power the harddisk and the powerd usb-hubs, so its not that it needs to put out more power than it can handle.
    But my gps (usb) recever takes com3 in cpc. So what i think is that maybe the irq adres has somthing to do with the switching of.
    I have changed the irq to the on i use on the com 4, probebly test it this weekend.
    MarcelP's Avatar
    Nov 2007
    Germany
    I think the ATMega88 am defective. Can one exchange so simply and again program??
  1. DSATX firmware bug?
    By zenfe in forum Power Supplies
    Last Post: 10-04-2008, 04:56 PM
  2. DSATX Shutdown Problem
    By killa996 in forum Power Supplies
    Last Post: 01-16-2007, 01:49 PM
  3. Strange power suplly problem.
    By seninha in forum Power Supplies
    Last Post: 10-22-2006, 06:32 AM
  4. Weird problem with DSATX and SP13000
    By arawas in forum General Hardware Discussion
    Last Post: 01-15-2006, 05:59 PM
  5. DSATX shutdown problem
    By gameboy in forum Power Supplies
    Last Post: 01-08-2006, 07:59 PM
