The ATX PowerGood signal (gray wire) is a +3.3V inpupt to the PC (+5V tolerant) and is high after all three supplies come up. You can fool a PC into turning on by tying this line to +3.3V (orange wires). The problem with doing this is that it will stay high for too long when the PC is told to turn off and it will hate you when you try to turn it back on. You should be able to cycle the power and get it to come on again though. I wouldn't recommend this as a permanent fix but you can try it to see if the power good signal is the problem.
LinkBack URL
About LinkBacks
