Results 1 to 7 of 7
Thread: Opus wont turn computer on anymore after dead battery
    Apr 2006
    Someone was in my car playing around with my carpc while the car wasnt started and it shut off on them. I tried starting the car after and the battery was dead. I have heard that the opus will turn off the computer if it drains the battery to much. Well since this happened my computer will not turn on. Is there something i need to do to reset it or what? Any advice at all would be good. The green light on the back of the opus isnt blinking at all anymore even though it is plugged in. It is an opus 120w btw. thanks
    Apr 2006
    buuump
    Mar 2006
    Colorado, but Canadian!
    I am guessing you got a jump since your battery was dead? Did you unplug the PC? If not, you could have just blown it up.
    I dont have an Opus, so I am not aware of this led. Is it is a power LED that is always on, or an LED that is only on when the PC is on?
    1.9in x 2.9in -- 47mm x 73mm
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    Have u tried disconnecting the positive battery terminal for a few seconds and then back on.
    My carpc worklog
    Apr 2006
    I have tried disconnecting the postive terminal and that didnt work, the computer stopped working before i jumped the car. There is a little green led in the back of the opus that blinks every 5 seconds if everything is ok. Right now there is no blinking, I was trying to see if it was getting power but i cant find my multimeter. I dont see how it wouldnt be though since none of the wires moved when it stopped working.
    Mar 2007
    Without knowing much about the opus itself have you checked all applicable fuses to see if any are blown. If all else fails you may want to voltmeter everything and ensure power is getting to the PSU. Many PSU's also have at least 1 built in fuse that is often soldered on directly to the board.
    Apr 2006
    I took the opus apart and found that the fuse was blown.. easy enough fix. thanks guys.
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 10:10 AM
  2. Replies: 5
    Last Post: 11-08-2005, 09:04 PM
  3. Help! Computer won't turn on anymore!
    By msumr282 in forum General Hardware Discussion
    Last Post: 04-10-2005, 03:58 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  5. Battery dead in car. Opus?
    By Chairboy in forum Power Supplies
    Last Post: 05-13-2004, 12:06 AM
