Results 1 to 10 of 19
Thread: M4-atx (6-30v) 250 Watt
    Newbie fritz_fx's Avatar
    May 2005
    Devonport TAS AUSTRALIA
    Hey Fellas, I've noticed that nobody has mentioned the M4-ATX here on the forums at all.
    So I figured you guys might appreciate a pic or 2 of it.
    Dimensions
    (L)123mm (W)94mm (H)28mm
    M4-ATX Characteristics
    Minimum Input Operating. voltage 6V
    Maximum input Operating voltage 30V (hard clamping will occur at 34V)
    Deep-Discharge shutdown threshold 11.2V
    Input current limit (fuse protected) Mini-blade 25A
    Max Output Power 250 Watts / 300 watts peak
    Deep Sleep Current Consumption. < 1.6mA
    Storage and operating temperature -40 to +125 degrees Celsius (storage), -40 – 65C (operating)
    MTBF 200,000 Hrs
    Efficiency (Input 9-16V) >95%, all rails combined, 50% load.
    Input connectors M4 screw terminal
    Output Connector ATX Power 24 pin (Molex P/N 39-01-2200) *Unit shuts down when internal temperature sensor indicates > 85C. This value can be changed with software.
    I'm not sure who I stole my avatar from, but I hope they don't mind, I figured it sums me up perfectly...... a pi$$edIdiot
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by fritz_fx View Post
    You noticed wrong:
    http://www.mp3car.com/vbulletin/powe...ed-m4-yet.html
    http://www.mp3car.com/vbulletin/gene...mobo-swap.html
    etc, etc...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    is there no port to access the pic's capabilities? Thats the only thing i wish the m2-atx added personally.
    Live mp3Car Facebook Chat
    Newbie jimmler's Avatar
    Jan 2008
    Cal. Central Coast
    I just ordered one of these, so we'll see how it works out. A couple things I'd like to see in a future release:
    1) The option of horizontal or vertical power connections(like Opus does). That right angle ATX is gonna cause me some grief in my installation.
    2) A different power input connector. The screw terminals are nice, but in a cramped area, it'd be a pain to tighten. Also that connector sticks way off the board, so again problems for my installation.
    3) USB programming instructions. In the downloadable version of the manual, they show the pinout for the connector, but no mention of how to talk to the supply or what you can change once you're connected.
    Stay tuned!
    -Jim
    Nipomo, CA
    Jan 2008
    Cal. Central Coast
    The M4-ATX arrived safely. I have only been able to give it a quick test. I currently have it configured as a standard ATX supply and with a beefy 12V bench supply feeding it, it powers up my VIA board, no problem. I have redesigned my layout a bit, so I can make the horizontal power connectors work, but that huge power input block has to go.
    As far as support from mini-box.com, they get an "F". Two e-mails and they have not responded to any of my requests for more info on the board. More details as I discover them.
    -Jim
    Nipomo, CA
    Mar 2008
    Its a paper weight for me so far. It doesn't operate correctly. It doesn't seem to work correctly for anyone. And I am going on 2 weeks of waiting for a reply e-mail back...so I wouldn't hold your breath.
    Try using your M4 with a 5 second shut down time. My guess is that it will take over 30 seconds to shut down..no matter what you put your dip switches on.
    *Note, be very careful when messing with the screw connectors for the power. If you touch the case with the screwdriver as you are unscrewing the positive lead, you may get some sparks..possibly damaging your motherboard/power supply.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I'd have to say not to even mess with it unless power is off.
    Any more opinions or feedback on this unit?
    Thinking of getting one, ...but...
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    The unit is great, the early units had some issues with the firmware, but the new units available now should be fine. I have most of the issues that we have faced with the M4 over here http://www.mp3car.com/vbulletin/powe...ur-m4-atx.html
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Newbie GhostRiderDad's Avatar
    Apr 2008
    HELP,
    I had my M4-ATX working just the other day, and I changed power supply as the battery source, and suddenly, its not working at all. I see the led flashing every few moments(like 15-30 seconds) but when I try to boot up the PC using the standard on/off and not the pulse...nothing happens. I Tried several times to switch power supply battery sources and it still won't work, and the LED is acting the same way. checked voltage to the terminals and its 12+ volts. so what could be wrong? Everything was plugged in and I could not figure out what could be shorting the PS, if at all. Did I manage to kill it? How would I test to see if I did kill it or not ? Anyone else have this issue?
    The LED flashing every 15 seconds I think means it is in the hardoff mode, and therefore it wont allow you to boot up the pc untill you apply a constant 12v to the ignition terminal. Have you tried it in "dumb mode" (all dip switches off) ?
    Fox Mulder
    2004 Toyota MR2
  1. FS: Top Mirco 250 Watt DC ATX Power Supply
    By archimense in forum Classified Archive
    Last Post: 08-22-2005, 11:09 AM
  2. WANTED: 250 Watt DC/DC ATX Power Supply
    By barrettg in forum Classified Archive
    Last Post: 09-14-2003, 02:55 PM
  3. Got my Keypower 250 watt ATX PS.
    By LESLIEx317537 in forum Power Supplies
    Last Post: 02-15-2002, 11:52 AM
  4. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  5. 12 V 250 Watt ATX supply
    By gizmomkr in forum Classified Archive
    Last Post: 02-07-2001, 11:27 AM
