Results 1 to 6 of 6
Thread: M2-ATX to power Carputer and xbox 360?
    Low Bitrate EaRNi's Avatar
    Mar 2008
    Lancashire (UK)
    ok, at the moment i have a M2-ATX and i am in the process of building a pc for my car, i have been thinking about putting my xbox into my car at some point in the near future.
    my question is, will i be able to run my xbox 360 and my car pc through the same PSU?
    also, is there a way to only ever have one or the other powered? never both at the same time!
    what do i need?
    Sep 2007
    Dawson, IL
    I do not think the M2 has enough power to supply both, 160 Watts
    Mar 2008
    Lancashire (UK)
    thats what i mean, could i not put a switch in the M2 ATX so i can flick between pc and xbox 360? then technically i wouldnt be powering both.?
    Elsewhere
    The engineering involved in pulling this off wouldn't be worth the additional expense of a second PSU...
    How about the Wiki?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by DarquePervert View Post
    You would have to add a number of relays just to switch all the outputs. You would lose the intelligent startup and shutdown timing features that the carPC needs for smooth functioning. The cost of parts and time to make something that barely works would not be worthwhile. You can use a second (probably less expensive) supply for the xbox, and be able to use both units simultaneously.
    ~Jimmy
    Mar 2008
    Lancashire (UK)
    cool, i will just do that then. thanks for your help
  1. Using an xbox as carputer
    By Shorty2301 in forum Newbie
    Last Post: 11-27-2007, 09:41 PM
  2. FT/FS Xbox 360 Premium will trade for Carputer
    By Zeroaviation in forum Classified Archive
    Last Post: 09-03-2006, 08:14 PM
  3. TRADE: Xbox 360 for Carputer
    By carfreak01 in forum Classified Archive
    Last Post: 03-31-2006, 10:47 AM
  4. The New XBOX 360 a new carputer
    By sdashiki in forum General Hardware Discussion
    Last Post: 05-13-2005, 12:56 AM
  5. XBOX, Carputer, power Question! ELECTRIC GURUS HELP!
    By EggrollXpress61 in forum General Hardware Discussion
    Last Post: 08-21-2004, 12:15 AM
