Results 1 to 7 of 7
Thread: m2-atx not coming one
    Jan 2005
    hey i hope this isn't already been brought up but i haven't had much luck searching the problem i am having is if i jumper the atx connector it will turn on however it will not turn on anyother way if i manually trigger the MB it will not turn on the only way i can seam to get it turn on is to jumper the atx connector any help would be great
    Thanks,
    yonu
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    what jumper settings? what you do have the ignition wire connected to? do you have the power switch wire from the m2atx to the motherboard connected, and the right way around?
    Jan 2005
    ok right now i am using a bench supply and i have tryed it with and without the mb switch hooked up and at the moment i have the jumper set at the default settings
    Jan 2005
    ok i tryed switching the connectors for the mb switch and still no go it will only turn n if i jump the atx connector any advise would be great
    thanks,
    yonu
    Jan 2005
    I am hoping someone can make a suggestion as i hate to have to send it back and wait on a new one to get this thing installed
    thanks Rob i checked what you talked about but no luck
    thanks,
    yonu
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by yonu View Post
    I have no more suggestions. You didn't really answer my question about the ignition wire, but if you checked it and it is good then nothing more to check.
    Jan 2005
    no the ignition wire is good as i am running it from a bench supply at the moment and boith wires are powered from the constant
  1. M2 ATX Amp turn on not working
    By CdRsKuLL in forum M2-ATX
    Last Post: 04-23-2010, 01:25 PM
  2. Xbox w/ M2 ATX and PSU convertor
    By MiniRX7 in forum Power Supplies
    Last Post: 11-25-2007, 07:45 AM
  3. Another M2 ATX Problem
    By mattfl in forum Power Supplies
    Last Post: 02-23-2006, 05:47 PM
  4. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
  5. New ATX PS coming out
    By dbinnc in forum Power Supplies
    Last Post: 01-26-2002, 02:34 AM
