Old pc much? Anyhew, I love the inverter route personally, I run a 1000W inverter in my cargo area with the pc plugged in and then route a power strip under the passenger seat for any and all sorts of stuffs including the touchscreen and usb hubs. Inverter even has a remote to it. Can also run stuff off it when car camping too which is nifty. Good quality inverters also have chassis grounds which eliminate near all noise from the system which is all the better. If you really wanna do it without an inverter, there is almost no way of knowing the power specs of that system without a watt meter. Plug this into your wall and then the computer into it and it will tell you how much you are using. The kill a watt I like personally because its just so easy to use (http://www.buy.com/retail/product.as...36&dcaid=17902)
Anyways, good luck!
LinkBack URL
About LinkBacks
