Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: M2-atx Override Switch
  1. #21
    Dec 2006
    Hey FusionFanatic, Is this the way I wire the switch if I was looking at it upside down?
    http://home.austin.rr.com/soloxp/ima...%20Switch1.JPG
    I appreciate your help and time FusionFanatic.
    Thanks Soloxp
  2. #22
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Dpdt Sw?
    IF it is a DPDT and you move one wire it will do what you want. If you use a DPDT with center off position you add the function of never turn on.
    ~Jimmy
  3. #23
    Dec 2006
    Quote Originally Posted by JimmyFitz View Post
    Thanks JimmyFitz,
    Well I just done soldering the switch, will give it a go tomorrow at lunch.
    [media]http://home.austin.rr.com/soloxp/images/pic/sw1.jpg[/media]
    [media]http://home.austin.rr.com/soloxp/images/pic/sw2.jpg[/media]
    [media]http://home.austin.rr.com/soloxp/images/pic/sw22.jpg[/media]
  4. #24
    Nov 2005
    Austin, Texas
    Quote Originally Posted by soloxp View Post
    It will work. Good luck. Talk to you soon
    ~Jimmy
  5. #25
    Dec 2006
    It is working.
    never turns off
    never turns on
    on/off with car
    Thanks JimmyFitz, beer on me.
  6. #26
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    glad you got it working solo
    ...where do you plan on mounting that toggle switch?
  7. #27
    Dec 2006
    Quote Originally Posted by FusionFanatic View Post
    Thank you too for your help FusionFanatic, I have the switch and led in the center console.
    I'm going to try to make a better diagram of the one I have. That way it's easy for the next person that wants to do this.
  8. #28
    Nov 2005
    Austin, Texas
    What you hooked up is the same as this:
    ~Jimmy
  9. #29
    May 2007
    Boston
    I modified the diagram I made for post#18. instead of using schematic switch symbols, it has the switch leads like you see it from the bottom of the switch. this uses a standard DPDT-C/O toggle switch.
    it's basically the same thing as your diagram Soloxp, just much cleaner LOL ... (next time you make a diagram in mspaint; use shapes and lines, not the paintbrush ).
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  2. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  3. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  4. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
  5. Replies: 2
    Last Post: 04-28-2002, 11:59 PM
