If your battery is low to begin with (below nominal charge), your alternator will NEVER charge it up fully since you use the alternator's output
power for your engine,
lights, carputer etc. Normal (non carputer'ed) cars don't have this problem b/c the battery is only used for a short minute to start. Well, not NEVER, if you get out on the highway for an hour or two that might charge it up fully. But thats usually not happening.
I've had this "where did my battery charge go" problem for awhile now. I've found that hooking up a small motorcycle maint charger at night to top off the battery works wonders for weird problems like this.
To use a multimeter to test for amperage from your car battery, first make sure EVERYTHING in your car is off. If anything is on, you might blow the multimeter fuse. Hook up the multimeter in
series with your car battery. You will have to unhook the positive terminal on the battery. The multimeter goes there similar to the following.
(BATT+)-----(MULTIMETER)-----(CAR)
Nothing will be hooked to the ground. The multimeter is going to act like a paddle wheel in a creek, measuring the flow of water (current), not how hard its pressing against the wheel (volts).
With everything off, you can get your baseline constant draw. By putting the multimeter between the battery and the car, you can see the overall picture. Then you can start
testing "downstream components" such as your carputer, stereo amps, etc. Find out where the current IS drawing, and where it IS NOT. This eliminates things to worry about. Until you find out where it isn't drawing, you won't be able to eliminate anything. You have to test to each device that uses the current. Testing a wire that goes to your amps and carputer doesn't tell you if its the amps or carputer. Get it?
