Results 1 to 6 of 6
Thread: The correct power supply
    May 2008
    I plan on putting together a carputer using this motherboard:
    http://h10025.www1.hp.com/ewfrf/wc/d...304167&lang=en
    I took the mobo and processor out of a pc I had laying around that I don't plan on using anymore. The pc has/had a 108w psu. I won't be running a cd-rom or a standard HDD (I'll be using a solid state drive).
    The problem I'm having finding the right psu is the connector. Almost all the psu units I've come across have a 20-pin atx connector. My mobo has a 24-pin connector.
    I'm I blind or am I just missing something?
    Thanks!
    Mike
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    your board needs an ATX 2.2 power supply (24 pin) the car ones are generally ATX 1 (20 pin). You should be able to either splice your old 24 pin connector on or add the extra 4 pins as per wiring diagram http://en.wikipedia.org/wiki/ATX .
    Are you sure it had a 108 watt total power supply? That seems far too small for anything Athlon 64 related!
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    The M4-Atx has a 24 pin connector.
    Sep 2007
    Dawson, IL
    Plenty of 20 to 24 pin ATX cable converters available, try a web search - here is one(checked store first but did not see one) http://www.newegg.com/Product/Produc...re)-_-12201001
    May 2008
    Quote Originally Posted by v8 scimitar View Post
    That's what I thought too, but it's true.
    Here's the pc it came out of:
    http://h10025.www1.hp.com/ewfrf/wc/d...04167&lang=en&
    Thanks for the info guys. I figured it was something simple like a converter, but I wanted to be sure that wasn't a problem.
    Jul 2008
    Panama City, Florida
    hey how did that slimline come out.
    what PSU did you use. I am using a opus 320 for my current rig. A friend is selling me his HP Slimline s3100n and i need to get the 20 Pin to small 24 Pin connector. Did you use the case it came with or build a new case.
    I plan to build a new case out of Plexiglass.
    long time ago the 1st gen slimline that hp released had real bad heat issues. You got any?
    Thanks in advance,
    Charles
  1. fried my carnetix power supply?
    By mustanglou in forum Power Supplies
    Last Post: 11-10-2007, 12:34 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. Power Supply
    By MrGee in forum Newbie
    Last Post: 06-21-2006, 05:44 PM
  4. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
