Results 1 to 8 of 8
Thread: DSATX nightmare
    Mar 2007
    Atlanta, GA
    DSATX nightmare
    So I've been using the DSATX for about a month now and it's working ok, except for the fact when ACC dies the PS dies with it. Note: I'm not too happy that I have to buy a Brainstem to fix this issue.
    So I buy a Brainstem and unfortunately can't hook it up due to my current layout. A fellow member here pointed me to a website that sold an extension cable which was perfect. I plug the extension cable into the DSATX, brainstem into extension cable, and then plug the brainstem directly into my serial port.
    Well like other people on here, with the brainstem connected to the computer, the computer won't turn on. So I unplug the brainstem from the serial port and sure enough it turns on. So with it still connected to the DSATX, I decide to turn on the computer, then connect it to the serial port. Sometimes this works, sometimes not (power shuts off immediately). I wasn't sure if this constituted hotplugging the brainstem because I always have it plugged into the DSATX (via extension cable) - only thing I'm doing is hotplugging it into the serial port.
    I finally managed to get into hyperterminal and started hitting keys to make sure I was connected. I then see something to the effect of "Defaults loaded" or something like that. Then about 3 seconds later the power dies. Sure enough I can't turn it back on.
    I disconnect the brainstem from the serial port. Again I turn on the computer and try to seat it back into the serial port. Again the computer dies.
    Now my current state is I get 4 red blinks on the DSATX and it appears to be stuck in this state. I've completely shut off the car and back on. Pulled the fuse out and its fine. Yes there is a fan connected but this is definitely not a temp issue as the 4 blinks suggests.
    This Brainstem has made things go from bad to worse quick!
    MarcelP's Avatar
    Nov 2007
    Germany
    I made it in such a way:
    Attach your Brainstem. Connect your DSATX to a battery (+12V VIN and Ground).
    Then connect with a laptop or any PC over "Hyperterminal" or similar to that brainstem, then you can configure it.
    Sorry for my bad English, German is better!
    I hope it helps you.
    My Project: German/English
    Mar 2007
    Atlanta, GA
    So I've tried resetting the DSATX - shorted pins A2 and B2 but I'm still getting the 4 blinks. It appears this thing is "stuck" in this mode.
    MarcelP - I don't think I can get into the brainstem until the DSATX is "on". At this point I can't even get that to happen.
    MarcelP's Avatar
    Nov 2007
    Germany
    Quote Originally Posted by jbradshw View Post
    That was with me also like that! As soon as a PC was attached and the Brainstem could I it not start!
    One can configure the Brainstem in addition, without attached Car PC. Simply only 12v attach and Ground and already can you it with the Brainstem configure. With me also this error was, there was wrongly set the Overtemp. some time ago. Thus it did not concern.
    Mar 2007
    Atlanta, GA
    So I tried programming it per the instructions with the firmware.
    It got all the way up to Sending Page #67 and now its just sitting there. How long should this process take?
    Mar 2007
    Atlanta, GA
    So it just sat there forever so I tried doing it again. I can't get the flash to finish. It gets to a random Sending Page # and just sits there.
    Just to confirm the text file said to set the port to 115k so I did that in the flashing program and in Windows Device Manager.
    MarcelP's Avatar
    Nov 2007
    Germany
    With me it took only few seconds!
    Mar 2007
    Atlanta, GA
    Yeah I'm about ready to throw this thing out the window!
    Zootjeff, is there any possible way of getting this thing swapped with one that already has the firmware applied? I'm pretty much at my limits with wanting to deal with this thing any longer.
  1. DSATX w/brainstem Problem
    By TeamRSX in forum Power Supplies
    Last Post: 04-03-2008, 08:01 AM
  2. Problem with new DSATX
    By jbradshw in forum Power Supplies
    Last Post: 03-31-2008, 06:59 AM
  3. DSATX nightmare
    By MastaShake in forum Power Supplies
    Last Post: 09-21-2007, 03:27 PM
  4. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  5. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
