I'm thinking about having a similar setup. You're saying these parts don't work well together?? Or not at all? What problems are you running into?
HELLO I TRY TO FIX A EXTREME CARPC
MY SYSTEM IS
VOOM II
M2ATX 160 WATT
INTEL Core2Duo T5300 1,73Ghz
RAM 1024MB DDR-II 533MHz CL4 X2
Jetway J9F2-Extreme
2,5" Festplatte 80GB SATA (Hybrid HDD, FlashON
Wireless LAN USB Buffalo
2 USB HUB D-LINK 7 USB WITH EXTERNAL POWER ( I , II )
1 USB 4 HUB ( CONNECT TO I USB HUB )
1 SLIM-LINE DVD+-R/RW Panasonic SLOT-IN USB ( CONNECT TO VOOM II )
1 WEBCAMERA LOGITECH USB ( CONNECT TO I USB HUB )
2 WEBCAMERA LABTEC CONNECT TO I USB HUB ( CONNECT TO USB 4 HUB )
1 BLUETOOTH FOR PHONE ( CONNECT TO I USB HUB )
1 BLUETOOTH LOGITECH KEYBOARD ( CONNECT TO I USB HUB )
1 USB SOUNDCART MAYA EX ( CONNECT TO VOOM II )
1 TOUCHPAD USB ( CONNECT TO USB 4 HUB )
1 USB VGA 2.0 CART ( CONNECT TO VOOM II )
1 USB TV TUNER HAPPAUGE ( CONNECT TO VOOM II )
1 USB SCANNER PLUSTEK M12 ( CONNECT TO II USB HUB )
1 USB PRINTER HP WITH BATTERY ( CONNECT TO II USB HUB )
1 USB GPS RECEVER ( CONNECT TO II USB HUB )
1 USB OBDII ( CONNECT TO I USB HUB )
3 VGA USB TOUCHSCREEN (THE 3 MONITOR CONNECT TO 12V AND NOT TO M2) (1 MONITOR CONNECT TO I USB HUB AND 2 MONITOR CONNECT TO II USB HUB ) THE MONITOR HAVE EXTERNAL POWER TO 12V BATTERY.
CAN THEY USE WITH M2ATX 160 WATT ?
ALL THE ITEMS THEY DON'T WORK ALL TOGETHER !!!
I'M IN THE MIDDLE OF THE PROJECT !!!
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
1. first off; do you really need all those USB devices in a carPC? LOL you won't have any space left in your car for passengers
2. have you bench-tested this system first to verify everything works? or did you just install everything in the car assuming it would work?
3. does the system work with just the bare minimum hooked up (no unnecessary USB devices)?
4. the M2-ATX is probably not capable of directly powering all those devices. I see your first USB hub is a powered hub; where are you getting it's power from? are your other hubs powered as well? and if so, where are you getting their power from?
5. some USB devices don't like being connected to hubs. these devices may need to be plugged directly into the motherboard's on-board USB ports (or through the on-board USB headers).
