Page 13 of 27 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 264
Thread: Everything You need to know about your M4 ATX
  1. #121
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I would have to attribute about 95% of the problems people experience with the Mx-ATX power supplies are user error. I have purchased 4 in the series and all have worked well, in fact all of them are still working today. I usually read the manual twice before touching the boards, and triple check all connections before firing it up.
  2. #122
    Apr 2009
    Quote Originally Posted by blk02si View Post
    I agree with you... I'll admit I was worried at first with my problems (self induced problems) and read some posts a few pages back that someone had the same issure and had to RMA it; so I was preparing for the worst. Currently the unit is working flawless and I will be setting up the USB support next. Outside the car I'm even running bench tests using an 18v Dewalt Drill Battery without a hickup.
  3. #123
    Oct 2008
    For installation reference:
    I studied the PC board quite a bit for installing this and noticed a design trait I really didn't like that much. Mounting pads on 2 of the holes are positive (+) flowing current from the primary input. You may notice they have an extra layer of clear insulation on them. I don't like this because if one was to use metal standoffs and tighten it down too much, the IC will short against ground. In my installation I used non conductive nylon standoff's just to be sure. Just though installers should know this since it's not marked anywhere in the manual.
    -Joe
    Thanks for sharing! When I installed the M4 in my custom-built case I wondered why these two holes had extra insulation on them, but now it figures. As I will be installing my new HQCT-i this evening, I will add some nylon washers between the standoffs and the M4 board.
    No problems so far with the M4-ATX btw. I use mode 1 to automatically startup/shutdown the PC in respect to the ignition state of the car and all is well. The only thing I encounter is when I shut down the PC via software and keep the ignition on, the PC will startup again after about 30sec to 1min by itself. Any ideas on how to prevent this?
  4. #124
    Apr 2009
    Antenna interference
  5. #125
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by bennierex View Post
    Add a hard switch in the ACC line?
    May I ask why you are running a startup / shutdown controller if you want to shut it down manually?
  6. #126
    Apr 2009
    Radio Interference?
    Is any else getting radio interference generated from the M4? I've hooked up a PC Power Supply to test it and all works just fine but as soon as I power up with the M4,there is so much interference that I cannot tune any radio stations
    One thing after another with this project.
  7. #127
    Jul 2005
    Motorcity
    Blog Entries
    1
    Are you powering the radio with the M4? If so don't, the HD tuner has built in line filtering. Usually poor reception has to do with antenna issues or poor grounds. Can you give more info or perhaps a wiring diagram about how your m4 and tuner are wired?
  8. #128
    Apr 2009
    I've tried powering the HD radio both from the M4 and without... I'll leave it powered seperate from now on.
    I have my stock radio still wired and using AUX for my sound input in my car. My stock radio also gets poor reception when the M4 is powered while the HD Radio for the PC doesn't get anything.
    I have my M4 powered to the battery with a 4 gauge power run and grounded in the trunk with another 4 gauge cable that I sanded down a 3" area and screwed a gold plated 2" ring adapter. I have all the connections soldered so I know they are getting good contact.
    I had the tuner run from the hard drive power from the M4 and grounded on the same terminal in the trunk. I've run the tuner to a seperate 12v source but even so, as I said above my factory stereo is also getting interference so I feel like the M4 is producing it
    I don't know where else to ground it... I'm getting the same voltage at the M4 as I am at the battery so I feel like there shouldn't be any resistance from the ground. Should I run more than one ground to the M4?
    Oh and the antenna I am using for the HD Radio is a low profile powered antenna that works great without the M4 on.
    It's definately the M4 as I have used a normal power supply plugged into an outlet and everything worked.
  9. #129
    Apr 2009
    No Fix, but a solution
    Well, I never found a fix for the interference caused by the M4. My stock radio gets some static added to it regardless (since the antenna is in the trunk w/ the power supply). I moved the HD Radio tuner along with a power antenna mounted under the dash up front with me, then bought a serial cable extension and long RCA so I could feed the HD Radio back to the computer. This worked well on my first test... just another $20 in cables.
  10. #130
    Jul 2005
    Motorcity
    Blog Entries
    1
    I'm pretty sure if the M4 were enclosed in an aluminum or steel enclosure the interference would be contained. Good idea on remote mounting the HD tuner though, I was wondering if that would work with a serial extension.
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 10:24 PM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 08:43 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  5. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
