Page 16 of 30 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 297
Thread: Everything You need to know about your M4 ATX
  1. #151
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Where is the red wire going in this pic?
  2. #152
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    It's going into the Accessory spot on the rocker switch.
    Edit: Wait, I lied. Those were the pics after I took the rocker out of the equation, that time it's not going to anything:
    And I was using a flat head screwdriver, or a power button (Tried both) to send the "turn on" signal to the Zotac motherboard.
  3. #153
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    i just posted this on my old thread but it might help..
    my m4 kept shutting the pc on and off every few seconds. it seems the problem is just the m4, idk if its just my m4 or everyones, but my m4 has done this on 3 differ mobos.
    i just had to hook up a relay through the mobo on/off to send pules until the m4 powers up, then the relay shuts off the signal.
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  4. #154
    Jan 2009
    Iowa
    The motherboard isn't even coming on. I have it hooked to the LCD, keyboard, and optical mouse. I watch the LCD, never blinks on, the keyboard lights never come on, optical light never comes on, and CPU fan never spins up. But with the regular power supply everything works just fine.
    I think it's something I'm overlooking somewhere. I've read through everything and gone over everything but I think it's like proof reading your own paper I'm missing a word somewhere and my brain is just filling it in.
  5. #155
    Jan 2009
    Iowa
    Quote Originally Posted by blk02si View Post
    For installation reference:
    I studied the PC board quite a bit for installing this and noticed a design trait I really didn't like that much. Mounting pads on 2 of the holes are positive (+) flowing current from the primary input. You may notice they have an extra layer of clear insulation on them. I don't like this because if one was to use metal standoffs and tighten it down too much, the IC will short against ground. In my installation I used non conductive nylon standoff's just to be sure. Just though installers should know this since it's not marked anywhere in the manual.
    Where did you obtain your nylon standoffs? I have regular standoffs, and some little red ... I think - cardboard - washers I'm planning to place in between, but wouldn't mind knowing where I could source some nylon standoffs.
    Edit: I found some on Digi-Key's website, but they're more spacers than what I'd think of standoffs.
  6. #156
    Jul 2005
    Motorcity
    Blog Entries
    1
    usually a hardware store like ACE will have them, The ones I use are actually nylon binding posts and I use nylon machine screws on either end.
  7. #157
  8. #158
    Jun 2005
    Crazyburn, Melbourne, Vic, Australia
    No that won't work. That programmer is for Atmel microprocessors. The M4 uses a PIC processor. You need a PIC programmer.
    '89 GQ Patrol
    TD42 (go the Diesel!) NEW: Now with DTS Turbo - woot!!!
    "It's times like these you go BUGGER!!!"
  9. #159
    May 2009
    overheat issues??
    I just got around to installing my mark II of my CarPC built on the M4 ATX. I benched it for about month prior to installation and all seemed fine. It seems to be fine during my morning commute, however during my afternoon commute when the temperatures are much warmer, the PSU seems to be dropping power to the system. My system temps are around 150F which is a little warm but not unreasonable. I have all the BIOS thermal protections cranked to max or disabled.
    When the PSU does trip, I have to leave it powered off (have a cutoff switch till I'm certain the system is good) for a good 5 minutes before powering it back up. Then it will run for a little while before it drops again. When stopped, I popped the trunk to see what's going on and I hear a high-low klaxon emitting from the PSU.
    Anyone else experiencing this issue?
  10. #160
    Jul 2005
    Motorcity
    Blog Entries
    1
    The M4 manual states if you are going to be running at of near full load forced air cooling is recommended. I would say more than 75% load or about 185w, You're going to want to put a fan over the top of it.
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 10:24 PM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 08:43 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  5. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
