Page 19 of 30 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 297
Thread: Everything You need to know about your M4 ATX
  1. #181
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I'm afraid i can't help you there as i don't know how to check the firmware.
    As i understand it there's only 1 way to do it and thats when the unit is powered up and you have the intelligent cable made up and connected to the software.
    In my case, it was just a good guess as i'd had it for ages, i got it just after they came out so i was pretty sure and proved correct.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  2. #182
    Jun 2009
    M4-ATX Input fuse rating
    what is the recommended fuse rating to feed the M4-ATX PS? I believe that it should be 20A for the +12V line and perhaps 3A for the Ignition line. Is this correct?
  3. #183
    Jan 2009
    M4-ATX no power problem
    Hi,
    I red many replies. I had a problem with M4-ATX power supply.
    I had connect all wires and after get power nothing happening.
    I searched for many hours and didn't find nothing about on internet.
    So, i decided to start from the beggining.
    I used a external car battery for test.
    The also deference was that didn't connect 12V of battery to IGNITION of M4-ATX.
    After cut everything worked fine.
    If anybody has the same problem, try it to connect only V+ and GROUND.
    I hope to help.
    Thanks to community.
  4. #184
    Jan 2009
    M4-atx ignition connector
    Hi,
    [Copy from manual]
    Power Input Connectors (bottom, right)
    Left Battery negative (GND) Center Ignition (switched battery, positive. Can test by connecting to Battery +)
    Right Battery positive (+)
    The bold enclosure text may be is wrong. I spent many hours to strat power supply and i didn't, until I connected only V+ and ground.
    It is possible somebody has same problem
    Mar 2005
    Hey does anyone have the dimensions on this unit...
    http://resources.mini-box.com/online...dimensions.pdf
    That doesn't appear to list the depth, though I might just not know how to read it. I could probably get away with 160W M2 instead, but more is better right...
  6. #186
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Do you mean height?
    Luckily I happen to have mine handy as it's just returned from being reflashed.
    Height is 30mm, this is from the highest capacitor to the bottom of the lowest solder joint.
    So a space of 35-40mm at minimum I would recommend.
  7. #187
    Mar 2005
    Enforcer sorry I did not reply earlier a bunch of things came up, but mucho gracias man. I really appreciate the info. And height is exactly what I was wondering about. That means I will have no DVD drive in my case, no problem though. Just an external USB one instead I guess.
  8. #188
    Jan 2006
    I don't even know where to begin...
    I have checked my wiring, re-wired it. Tried multiple hardware (different RAM, HD, etc). But for some reason my computer randomly reboots (under Windows XP and Windows 7).
    I can take the M4-ATX into my house (along with the whole computer, lol) - take a 12V adapter, wire it up and run it successfully. But as soon as it is in the car it will work, then my PC just reboots.
    Could it be a firmware issue on the M4-ATX?
    I even went into the BIOS and watched the power hardware options - it really did not fluctuate much.
    Grrrrrrrrrrrrrr.
  9. #189
    FLAC WuNgUn's Avatar
    Sep 2007
    It's clearly a power issue...and it's clearly the M4 or your wiring.
    What gauge wire are you running?
    Good ground?
    Where is the ground?
    How is your car battery?
    Does the PC do this when the engine is running?
    Just a few questions
  10. #190
    Jan 2006
    What gauge wire are you running? - 8 Guage
    Good ground? - Yes, moved it twice, even ran a ground directly to the battery.
    Where is the ground? - right now battery, was on frame.
    How is your car battery? - good question, no idea.
    Does the PC do this when the engine is running? - just runs, no issue there.
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 10:24 PM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 08:43 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  5. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
