I am using the DSATX right now, but I also have the M4atx for my next project. Question is, can I one the M4ATX as I use the DSATX, namely, sleep mode with Windows 7, leaving 5V on, going to deep sleep (5v off) when the battery is running low? How?
Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
Skin: MetroSex on the Beach preview
07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
I have a question - if I am getting power fluctuations would a capacitor help with that?
Thank you blk02si and jpinkerton for posting pix!!!
Some of the lingo is hard to follow.
Doesn't matter if you're tech savy or not.
Some of the info is useless w/o pix.
I'm in the process of building my Nitro-Puter (posted on Nitro Forumz) but the manual for this M4 is horrific and came here for relief, got some clarification but I'm more of a visual person. I'm not to that point yet as I'm doing some custom fabrication but I'm sure "I'll be back".
Thank you all other fellow hobbiests, hackers and geeks or all of the above! :-)
Current Project:
2012 Silver DodgeRAM CrewCab HEMI
16gb+64gb 7.7" Verizon 4g LTE Galaxy Tab
An M4-ATX setup/monitoring tool for Linux, Mac and *BSD is available at http://ram.umd.edu/wiki/Public/Software/m4api . It supports nearly everything the OEM setup application does, including getting and setting all configuration variables.
Very nice! Thanks for the link knyt.
I am doing another build with an M4 where I want to run FREEBSD in a server type environment.
Anyway here is a pic. It's pushing a full ATX MSI board, 1gb of ddr2-800 ram, dual core intel processor, 2.5 harddisk, and a ATI all-in-one video card / TV / FM tuner card on a supermicro PCI-E riser. It pushes all of this no problem, barelyu even gets warm in this test chassis. (installed vista just for kicks and vista rates this card 5.9 for aero desktop and 5.3 for gaming, so I know it's pulling some juice)
And the plot thickens, here is a sneak peek at my new M4 powered rig I've codenamed voltage.
Yes, that is 4 gauge copper cabling going to the M4 from the battery bank.
This is intended for a marine application, the laptop drive is going to be replaced by a sata SSD.
I am going to setup the ignition line and play with the programmer software more, but I need to read and research first.
The battery array is 2x Optima deep cycle in parallel.
after a few hours of hard use the M4 is barely warm to the touch, and the array voltage is down to 11.9
I've realized I also need a large disconnect relay, when connecting the batterys there is a large spark when the lead first touches. A lot of current behind the optima battery pack.![]()
I'm looking for a PSU to power my mini-itx carpc.
I've read that the M4-ATX had a few firmware issues. Have these all been cleared up, and is mp3car.com's stock all with the latest firmware?
I was looking into M2-ATX but it seems to be out of stock. I'm not going with a very powerful PC so is there any other advantage to getting M4 other than raw power output?
I purchased mine 2 weeks ago, had zero issues with it. Has firmware 2.0 on it.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
