Page 24 of 29 FirstFirst ... 14151617181920212223242526272829 LastLast
Results 231 to 240 of 284
Thread: Everything You need to know about your M4 ATX
  1. #231
    Jan 2005
    Richmond, VA
    Quote Originally Posted by valantis544 View Post
    I put the mode on the p0 which is the only mode i think the m4 goes on without ignition and i gave power to the main line. The psu turned on and gave me a short beep as it should. After that i connected the ignition line but there was no beep.
    I'm sorry, I forgot to mention, can you repeat the process with p1 mode. P0 mode is standard psu mode, which I'm sure you knew. The reason why is that I have a suspicion that this chip that is connected to the on/off headers is bad, so I need to know its logic table, when the ignition is low and high. I'm referring to a very tiny chip on the board, if you look kind of behind the on/off headers to the right a little, there is a tiny device called "U3". Unfortunately, I don't have magnifying lens, but do you think you can identify the device number imprinted on the device?
    As far as your amps powering, maybe try it in other modes perhaps.
  2. #232
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    I have a DSATX in my old carPC, and I am building a new one, using a M4-ATX. On the DSATX, the countdown timer is set via pots, or via programmable via a serial interface. It appears that the M4-ATX has the same feature, a programmable countdown timer. Both of these send a pulse to the MB on/pff switch when the time is up, after power on the ign (or ACC) line has dropped.
    However, the DSATX has an additional feature, where if the countdown timer is running, and you short a jumper (on JP8) momentarily, it will drop the countdown timer to zero for that single shutdown sequence, and send the on/off pulse to the MB. Is there any way to replicate this on the M4-ATX?
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  3. #233
    Sep 2005
    Bellevue, NE
    So, that would be a no?
    Core Duo CarPC
    CarDomain page
  4. #234
    Constant Bitrate knownchild's Avatar
    Dec 2010
    IOWA
    NEED Help!!
    Ok i read the forum and i am just confused, do pins 6 and 7 go to the motherboards on/off??
    Also is this diagram correct↓
    If this is correct where do the other pins go?
    Here is my notherboard pins↓
    Never accept STOCK equipment.
  5. #235
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    Quote Originally Posted by knownchild View Post
    they both do. one goes to one side of the motherboard on/off, and the other goes to the other side
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  6. #236
    Dec 2010
    IOWA
    Quote Originally Posted by sk8rjess View Post
    yup i understand that now i just need to know how the other pins connect to the mobo
  7. #237
    Nov 2007
    well, the usb ones are correct, those never change throughout all motherboards.
    someone correct me if i'm wrong, cuz it's been years since i've even touched my m4, but:
    pins 1-4 are to hook it up to USB. i'd find an old usb cord you don't use, and splice it for use on the m4 - that's what i did.
    5 and 9 are, well, ground.
    and 8, if i remember correctly is for your amp switch.
    they call me hack
  8. #238
    Dec 2010
    IOWA
    thank you
    I literally figured all that out 10min before your post, thank you
  9. #239
    Nov 2007
    ha no prob man
    they call me hack
  10. #240
    Dec 2010
    IOWA
    OK so now i have a new question my computer turns on perfectly when i had all the dip pins off (in the up position) and when i have dip switch pin 1 on (down position) it should turn on my carputer after 60 sec right? because its not turning on now
    dip pin 1 being the one closest to the power cords.
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 09:24 PM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 07:43 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 12:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 01:57 PM
  5. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 08:06 PM
