ICSP, can i use my brainstem for this? http://www.acroname.com/robotics/par...-INT-CONN.html
http://store.mp3car.com/Brainstem_TT..._p/com-021.htm
Anyone having problems with their M4 turning the computer back on after it tells it to shut down?
I've set my PC to shutdown when I turn the car off. No hibernate, no standby. The M4 will shut it down and approximately 1 minute later, it turns it on again. To be sure it doesn't do this, I have to turn the power off to the PC itself.
Anybody experienced this issue? The M4 is a giant hunk O' junk for me. I"m going to go back to my Carnetix regulator and P120 if I can't figure it out. That combination has worked flawlessly for years.
Want to:
Make sure nothing is shorting your Acc line
I did reset it with no change in results. However, Enforcer's suggestion to check the accessory line is a good one. For reasons that I will not delve into here, I have two computers in the car, both triggered by the same accessory line, which means I have two PSU's in the car.
The PSU for one of the computers seems to have failed (it's buried in the dash and I have to dig it out) and that may have caused a short.
Want to:
is there a way to make the m4 switch on the mobo quicker. when it is set to hardoff and the 5 volt rail is gone, it takes 5 sec before the fan starts to spin.
When i use an regular powersupply and unpluged from the 220 volt (us 110 volt) plug it in and directly press the on switch it spins up within a second.
Is there setting in the usb controle sett to speed things up?
