maybe its the first production -models that had some floors, i probebly have a later one, because it preforms perfect.
The only thing you should know about the M4, is they suck balls!
With that said, I have one for sale!!
is this product really that bad? I need a power supply that will give me as much wattage as possible for as cheap as possible. Based on that, the M4 seems the best choice. If i were to buy one now, it would have the updated firmware and not so many problems, right?
After I loaded mine with the latest firmware I've had no issues.
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
I've had 0 problems with mine now that I've got the new firmware version.
1.3 is the latest that I'm aware of.
Jan Bennett
For whatever reason, mine couldn't power my 2 sound cards (just static) and the display was wavy and fluttery...
Both M4's behaved the same way...
My OPUS 320 works perfectly...
You can have my M4 if you like...if you want to chance it!
if you dont mind me asking WuNgUn, why arent you using the M4? And what version of the firmware is loaded on it? when you tested it where there any problems?
