Page 7 of 27 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 264
Thread: Everything You need to know about your M4 ATX
  1. #61
    Apr 2008
    so do you think that it was just not enough power to run it all maybe? i will be running an AMD Athlon XP 2800+ with onboard sound card and a Geforce FX 5200 video card. do you think the M4 will be able to power that? thanks in advance.
  2. #62
    FLAC WuNgUn's Avatar
    Sep 2007
    The OPUS support believed that it had something to do with powering the monitor...
    I used an M2 to power mine. He said it would help if I powered everything off the M4.
  3. #63
    Sep 2007
    Quote Originally Posted by moelsaied88 View Post
    I powered a 2800+ on a full ATX with an ATI X1050 and 2 sound cards...
    They told me to run the monitor off it too, it can handle it, so...
    I never did however, test that...I just found a deal on an OPUS and went that route...
  4. #64
    Sep 2007
    What mainboard are you using?
  5. #65
    Apr 2008
    its an asus KT880. it has an onboard sound card that i would be using. i would also be using a 250 gb hard drive and a couple of fans.
  6. #66
    Sep 2007
    I have to think that you won't be over powering the setup from what I can tell...
    What I can tell you is, I can't say for certain that the M4 will work for you. Obviously, my setup had issues with both M4's and both mainboards I tried...
    What that issue was, is still unknown.
    I'm thinking a ground loop or ground issues.
    They said something about the monitor (touch screen), but I also tried it with my 22" LCD plugged into it, and it too had the wavy display and static from both sound cards...
    I also tried it with NO monitors!
    I just think the M4 isn't the best PSU out there. But for the money, it's a good deal...and I'm sure most people don't have issues with it...
    If it doesn't work for you, maybe you can sell it to Kibble...
    All I know is, it's gathering dust in my attic!
  7. #67
    Apr 2008
    did you try powering the screen straight from a cig lighter? i bought the lilliput that has the auto on feature. i honestly didnt even consider powering the screen from the psu, would just be the pc itself.
  8. #68
    Sep 2007
    No, never tried that...
    I had the touchscreen wired into my M2 before I learned about the hidden options (power on options)...
  9. #69
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread cleaned to remove extraneous conversations.
    Want to:
  10. #70
    Newbie kensbey's Avatar
    Jul 2008
    brisbane australia
    no power signal...
    hey, i recently got an M4-atx... and having a small issue... it wont send the bootup/ shudown commands to mb. the time part works.. however. i know this because if i connect a normal switch to the jumpers on mb, 5 seconds after the ignition comes on i can turn the pc on... and it cuts power at the right time after ign goes off.. just cant get it to run the switch on the mb... ne one had this problem?
  1. M4 ATX USB connection
    By Arby in forum M4-ATX
    Last Post: 08-10-2009, 10:24 PM
  2. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 08:43 AM
  3. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  4. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  5. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
