Results 1 to 2 of 2
Thread: Opus 250 Question
    Newbie jdamb89's Avatar
    Jun 2007
    Miami, Fl
    Opus 250 Question
    Hi guys. I just finished wiring my Opus 250 to the battery and decided to hook up the computer for a test. There is one thing I m confused about: where on the MB does the green and white power switch connect to? I see no double pins on the MB, just two triple pins. I am using a dell Dimension 8200 MB. If you guys could help me out that would be great.
    Jun 2007
    Miami, Fl
    Scratch that guys. After I did some more investigating on the MB I realized what the issue was. Dell's power switch pins were part of a 9 pin array that ran that hard drive activity light and some other things and it was connected via a 15 pin flat cable. Strange. Anyways, I was able to isolate which pins were the power by guess and check, so I am up and running.
  1. Question about 12v input wires for Opus PS
    By Nola111 in forum Power Supplies
    Last Post: 02-07-2008, 02:48 PM
  2. opus 250 and itx
    By cano in forum Power Supplies
    Last Post: 02-07-2007, 04:59 PM
  3. Opus 90w power switch wire connection question
    By Tim97rs in forum Power Supplies
    Last Post: 05-13-2005, 08:37 PM
  4. Question about Opus 150w and my motherboard
    By Impalaman in forum Power Supplies
    Last Post: 02-09-2005, 09:22 PM
  5. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 02:32 PM
