Results 1 to 5 of 5
Thread: CNX-P2140 12v on both outputs
    Jan 2008
    Southern Calif
    Well I think you can use the Primary rail to power both your PC and the monitor. You can then use the Secondary rail to power a usb port 5VDC.
    May 2008
    Thanks... so will the screen be adversely affected by the standby power when the ignition is off?
    Jan 2008
    Southern Calif
    Well if your screen has auto detect, then it should turn itself off when there is no video coming in.
    May 2008
    Wow... for some reason these posts are getting all out of whack... must be a timezone thing...
    Yeah, the screen will auto power off... well, it goes into its own standby mode...
    Thanks, I will try your configuration and see what happens...
    May 2008
    Hi there,
    I posted this on the Carnetix forum but that forum seems to have gone quiet lately, I hope you guys can help me...
    Forgive me if this is a stupid question, but am I right in understanding that the P2140 cannot have 12v input and 12v output on both primary and secondary outputs? Wouldn't this be a fairly common configuration? My battery outputs 12v, my PC requires 12v and so does my screen... If it is the case that this setup doesn't work, how would I go about configuring 12v input, 12v PC and 12v screen?
    Cheers...
  1. 12V USB Hub, Help!
    By spoonraker in forum General MP3Car Discussion
    Last Post: 10-30-2008, 11:42 AM
  2. inverter and p2140
    By russian_mafia in forum Power Supplies
    Last Post: 04-10-2007, 05:36 PM
  3. How to ideal wire +12V to LCD (Xenarc)?
    By urosbe in forum LCD/Display
    Last Post: 12-30-2006, 04:53 PM
  4. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 12:47 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
