You could have the signal from the button that turns the lights on when you open the car door short the IGN signal to the carputer via a relay. You could then have a pressure sensor under the driver seat that does the same thing.
This way, when the door is open and/or you are sitting in your seat, the carputer will be starting before you even put the key in the ignition.
LinkBack URL
About LinkBacks
