Yeah it should work fine.
My carpc worklog
Thanks. Would this be a better way to go then getting a DC-DC 12V supply and then using a 19.5V laptop car adapter?
The P1900 install doc says it puts out +19.5V when jumpers are set for +19V.
Mine is set for +18V, but tests at +18.5V
Here it is verbatim:
"JP6 allows you to select the output voltage that appears on the Primary Output (J2 Pin 4). The selections are +18V, +19V, or +20V as shown below. Note: the actual voltage is set approximately .5 Volts higher to compensate for any wiring losses you may have in your installation."
Does this thing work as a startup/shutdown controller or do I need something separate for this?
It says it handles standby/resume but doesn't say anything about hooking into my power button.
You'll have to hack it into your power button.
Want to:
