Results 1 to 3 of 3
Thread: P4 Connector Voltage
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Dell motherboard stated showing a steady amber power light which according to the troubleshooting manual could be an internal power problem. I had rigged a P4 connector (joined to ends) from the M2-ATX to the MB and wasn't very tidy joining the wires so i figured that was the problem; redid everything like it was supposed to be in the first place; reconnected; powered-up - same thing! steady amber light
    Something told me to test the voltage and i get 0.00 volts from the P4 connector. I'm pretty sure there should be some voltage reading but i just want to confirm
    What voltage reading should i get for the M2-ATX P4 connector??
    Thanks in advance
    Vendor - Qube colin's Avatar
    Dec 2006
    The P4 connector should have 2x12v and 2xground rails. They're separate rails because some CPUs draw more power than a single rail should supply...
    I rigged one up the same way with two ends and some electrical tape Works like a charm...
    Sep 2006
    War-Town, GA.
    Yeah, mine worked also for a while, i think the M2 went bad for some reason 'cause I'm not getting any voltage reading. The strange thing is that other than that, every thing else is working - the fan is spinning, the motherboard light come-on, i can hear the HHD spin-up and the computer light is on (indicating a fault); all i get at the lilli is "no vga signal"
    Oh well, off to buy another one.
    Thanks.
  1. What is best: small epia1000 or big p4 2.2
    By xpluis in forum General Hardware Discussion
    Last Post: 11-30-2006, 09:48 PM
  2. Trying $145 Migrus P4 itx for second install
    By VehicrossPC in forum General Hardware Discussion
    Last Post: 02-25-2006, 10:03 PM
  3. power requirments for p4
    By SuperFastCVT in forum Power Supplies
    Last Post: 01-02-2006, 11:29 PM
  4. p4 MOBO Recomendation
    By septicdeath in forum General Hardware Discussion
    Last Post: 01-22-2005, 05:31 PM
  5. MII-12000 or my spare P4 for carputer
    By Bootbox in forum General Hardware Discussion
    Last Post: 09-20-2004, 03:11 PM
