Results 1 to 10 of 10
Thread: which mp3car power supply suits my pc board?
    Nov 2007
    Hi all,
    i am installing my carpc, i use pc board ECM-CX700 from avalue.com.tw. pix is here
    i am now using an ATX PSU from my old desktop to power it up as a work bench power supply. setup has completed with great RR front end now is the time to put it in the car but i dont have a PSU with startup shutdown controler
    i checked out mp3car store and dont really know which one is suitable for my mobo as it doesnt have normal 20 pin atx connector but only a 4 pin (see pix)
    could someone please advise which PSU is suitable
    thanks
    Nov 2007
    40 reads, no advise. would it be that hard?
    Elsewhere
    I suggest a 12v regulator.
    I also suggest reading the FAQs about choosing a power supply: http://www.mp3car.com/vbulletin/advfaq.php
    How about the Wiki?
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    according to the specs for that board (on avalue.com.tw), it can be powered with a "Single 5V ATX or 5V/12V ATX Power Input".
    power consumption is:
    • Power Consumption: [email protected], [email protected] (with VIA Eden 1.5GHz & 1 GB DDR2 533 SDRAM)
    • Power Type: AT/ATX Power
    "intelligent automotive ATX PSUs" have built-in startup/shutdown controllers. the M1-ATX can handle that system with ease (and it's the cheapest "intelligent" PSU in the MP3car store ). it can provide 10A@5V and 2A@12V which leaves you plenty of headroom for additional components. use a laptop HDD (which gets its power from the 5v rail) and you'll have enough power on the 12v rail to power your monitor (most 7" or 8" LCD monitors use less than 1A).
    good luck
    Elsewhere
    But it's also specifically designed for an ATX board.
    I'm not saying it can't be used or wouldn't work. But there are cleaner, more elegant solutions for this setup.
    How about the Wiki?
    May 2007
    Boston
    I would think that an "all-in-one" device like the M1-ATX (or other intelligent PSU) is the most 'elegant' solution possible in this case...
    otherwise you would need 2 or 3 separate devices to get the equivilent funtionality. you would need a startup/shutdown controller, +5v DC-DC regulator, and [possibly] a +12v DC-DC regulator.
    Nov 2007
    thanks all for your inputs, i also think M1-ATX looks ok for my mobo, but i am just wondering how the board communicate with M1 for turning on and off the PSU if i dont use the 20 pin ATX connector
    Elsewhere
    Quote Originally Posted by FusionFanatic View Post
    Considering the M-series PSUs are designed for an ATX motherboard (which this is not), you have to "fool" the PSU into recognizing a connection (shorting pins 13 & 14 on the 20-pin ATX connector).
    In my mind, that's not particularly elegant.
    There are 12v DC-DC regulators available that need nothing more than a connector for the motherboard.
    Hey wow...
    A Carnetix P2140 has all of this built-in.
    Looks pretty elegant to me....
    But what do I know. I've only installed a few vehicle PCs...
    How about the Wiki?
    May 2007
    Boston
    Quote Originally Posted by DarquePervert View Post
    true... but that's very easy to do.
    true... but that doesn't make it any easier.
    Hey wow...
    it has the features built-in, but it can only provide 3A on the +5v [secondary] output. that motherboard requires at least 3.5A @+5v. 2 separate devices would still be necessary. not very elegant if you ask me
    Feb 2007
    Maryland
    But if your mobo can take 12v and not just 5v, you can still use the 2140. The 12v primary line provides 11 amps
    CarPC status:
    [XXXXXXXXXX] 100% Complete
    [XXXXXXXXXX] 100% Installed
    [XXXXXXXXXX] 100% Software
    CarPC v1.2 is now in effect. Software updates and hardware additions to come.
  1. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  2. Car Battery Charger / PC power supply
    By stpenn123 in forum Power Supplies
    Last Post: 01-28-2008, 12:33 AM
  3. Casetronic C137 120watt power supply
    By Change in forum Power Supplies
    Last Post: 11-13-2005, 09:15 PM
  4. PC power supply - no external power switch
    By Zombietime in forum Power Supplies
    Last Post: 11-29-2004, 10:22 AM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
