Results 1 to 5 of 5
Thread: Replacing an ITPS
    Constant Bitrate ivanmx6's Avatar
    Dec 2006
    Dorset, UK
    Replacing an ITPS
    Hi,
    I've just bought a Lilliput DY-845 PC with an ITPS built into the case.
    I understand from reading here that the ITPS is not really suitable for in-car use as it can't handle cranking, so I want to replace it.
    I need the PC to be able to start and shutdown remotely (ign key) and have battery drain protection.
    I've read the FAQs and have looked into the power requirements:
    The PCs power drain is apparently 40W but I'll also be attaching USB GPS, USB WiFi adaptor, a small USB hub and occasionally a USB keyboard.
    I've looked at the M2-ATX which seems suitable but there are so many out there it's difficult to see the wood for the trees. My budget is about £50.
    What would you recommend?
    Thanks.
    Oct 2006
    DSATX, or Opus150, both great products!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    M2 will work just fine for you.
    Want to:
    Dec 2006
    Dorset, UK
    Cheers
    M2-ATX ordered. The DSATX is almost 3 times the price.
    Dec 2006
    Dorset, UK
    Fitted and working a treat.
    Had to splice a couple of cables as the connectors were different, but that was only a 5 minute job. The worst bit was trying to mount the bu66er securely as the ITPS used custom pillars.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Itps
    By Bugbyte in forum Classified Archive
    Last Post: 10-08-2005, 03:40 PM
  3. Powering Theory...input welcome.
    By oekundar in forum Power Supplies
    Last Post: 07-18-2005, 03:25 PM
  4. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  5. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
