View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 13 of 63 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 628
Thread: Solar panels?
  1. #121
    Jun 2008
    Houston
    oooh you should put a small co2 cartridge on the car, like the ones used to power icing canisters for cakes, or the ones that power airsoft/pellet guns, then install a servo with something to puncture the cap at the end. If its a light car and doesn't have a very big motor to resist the external force then you just got yourself rocket car!!!...well at least for like 5 seconds you do.
  2. #122
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    stay with me on this;
    what if he put TWO, yes two CO2 cartridges, then he'd have like 10 seconds of extra time.
    Or even better still, he could have the CO2 cartridges pointed towards a micro-wind-turbine generator and that would charge up the batteries. so when the car is running low, he can activate the CO2 and get more runtime.
    I also hear that using the right tires will help. There are a lot of guys that use smaller wheels, that way there is less rotational mass, and since they are smaller they will spin faster, but require less battery to do the same work.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #123
    Jun 2008
    Houston
    Your logic is FLAWLESS!!!! Maybe we should build this car, then we will win the Nobel Prize. Keep him from getting all the glory. We still need to work a hamster in somehow though...and maybe a bottle rocket or six.
  4. #124
    Started best thread ever
    Jun 2008
    Quote Originally Posted by figfry View Post
    lol how would i get the small wind turbine generator?
    i could put that on the outside of my car or something so it hits when i run! then it will help recharge and i could get multipule.
    any links for one like that?
  5. #125
    FLAC Chairboy's Avatar
    Jan 2004
    Quote Originally Posted by monkeyracer View Post
    For 100% efficiency, consider simply removing the wheels altogether.
    Chrysler 300 - Fabricating
    http://hallert.net/
  6. #126
    Jun 2008
    Quote Originally Posted by Chairboy View Post
    that wouldnt b 100% efficiant because it wouldnt move!
  7. #127
    Jan 2004
    It might not move, but it also wouldn't expend any energy, ie 100% efficiency.
    http://hallert.net/
  8. #128
    Jun 2008
    yea... sure... but isnt the object of a car to move?
    yea...
    i'll try to fit 15 broken solar panels.
    i also need to figure out if i can attach a belt around my wheel shaft so when it moves like have a gear in the middle of it so when it goes around it spins the gear and have that attach to something?
    like a tiny generator or something?
    any links please
  9. #129
    Jan 2004
    Oh, you want it to move! Ok, sorry 'bout that. The 15 broken solar panels are a good start, consider boosting their power by placing some flashlights on the car that shine directly into them. If you can power the flashlights by hooking them into the generator (an electric motor generates power when it's turned by an outside force, you know, so you could just use a leftover R/C motor as the generator) then it would be a closed cycle and even MORE powerful.
    http://hallert.net/
  10. #130
    Nov 2006
    Youngstown
    Why not use an array of 20-30 mirrors (cheaper than solar cells) mounted on the body of the car. Aim them all at a center focal point, maybe a glass vial filled with water. Then rout 2 lines from the vial to an small steam turbine and condenser. When the sunlight hits the mirrors it will be directed at the vial, causing it to heat up and turn the water into steam. The steam would then travel to the turbine causing it to spin, and exhausting most of it's energy. From the turbine the steam/ water would travel to the condenser and get pumped back into the glass vial. Rinse and repeat, then all you would need is a small generator attached to the turbine : )
    But rather than trust all of us why don't you ask this guy. I'm sure he could help you refine your theory.
    "Who run Barter Town?"
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 06:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 01:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 01:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 11:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 05:00 PM
Tags for this Thread
