how do i know exactally how long to keep it in the oven?
and could i let it dry without being in the oven?
where can i get the epoxy again?
hardware store?
Sad to say it would probably be the #1 work log and "show off your ride" of the site.
Just pictures of the yellow glob with black flakes in it. People show up and not have a clue why everyone is saying "Great job!" "Cool Ride", "How do you do that fantastic fab work?!", etc.
My opinion is my own.
hardware store?
Hardware store will have epoxy, but the best quality stuff with the best performance is sold at drug stores. It's a type of epoxy called 'Astroglide' because the performance is so slick. It's very heat sensitive, so you'll want to monitor the chemical reaction with a thermometer. The most sensitive cheap ones are baby ones (because they have such precision fevers).
Also, for the Solars, you might alternately use bananas instead of flowers, especially if you live in an area that doesn't have very many daisies.
When applying epoxy, it's important to wear gloves to protect your skin, so ask your parents to go to the store and get you some astroglide, a bunch of big bananas, a baby thermometer, and rubber gloves.
Chrysler 300 - Fabricating
http://hallert.net/
in the oven, the paste will start to get shiny, this is when the top coat starts to liquify, exactly 30 seconds after that (have a timer ready) it will start to turn hazy. That's when you have to take it out. Don't forget to wear hot-pad gloves, and keep your windows open, the chemicals in the paste can be toxic if not handled right.
Let it cool for at least 30 minutes before you touch it.
The lexan body will need to be completely covered for it to work correctly, any exposed lexan will melt and ruin the entire process. it's got to be at least 1/8th inch thick to properly insulate the lexan too.
The thermometer needs to not be digital too, that will mess with the thermoreactions.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
It needs about 450F to 550F (depending on the quality of solars extracted) to liquify them enough to bond them together.
How you get the heat is up to you. You can use a flame torch, but you would have to be very careful as direct flames will ruin it. The oven is the safest.
1.9in x 2.9in -- 47mm x 73mm
